2008 Ford Edge no heat
Petemon717
check to make sure the coolant level is at or slight above the cold fill range (above the seam) when the Edge is off, cold, and parked on level ground. Low coolant can do this. It may be a blocked heater core, but let's keep fingers crossed on that.
How many miles on the Edge, and has the coolant ever been flushed? I think Ford calls for 105K for first change, then every 60K thereafter.
