Suggestions/Opinions - 2011-2014 Edge Headlight Lighting
Hey there!
My 2011 Edge Limited came with factory installed HID lighting with D3S bulbs.
As many have noticed, the light output and color temperature is really lacking. I believe its 4300K.
What do you recommend? Get an aftermarket HID kit or just purchase a replacement D3S bulb at 5000K or 6000K?
After checking options available from TRS, looks like I don't get any aftermarket HID kits available.
Only thing I see that I can get (other than LED interior lights and turn signals, etc.) is the D3S Osram Xenarc 66340 CBI bulbs.
Has anyone tried these out in a '11-14 Edge or '11-15 MKX? If so, do they have a good light output? Im sure they are brighter than stock. I also checked and see that I have Osram Xenarc 66340 (Non CBI) currently installed.
https://www.theretrofitsource.com/d3s-osram-xenarc-66340-cbi-49680.html?carDisplay=2011+Ford+Edge+%28HID+Equipped%29&preselect=&preselect_restrict=1
If you have a 2011, you probably have the regular Osram 66340 . Later on, maybe 2012/2013, they started using 66340 HBI. Searching online, HBI might stand for "High Beam Improved", but they are better than non-HBI. I found a good deal on a pair of HBIs & saw a noticable improvement. The CBIs are supposed to be even better (though I did not try them).
I do have the 66340 installed. Did you notice if the color temperature was the same on the HIB as it is on the regular?
I since purchased and installed some 6000K D3S replacement bulbs (Not HID Kits) from Dan over at Drive Bright and they have a much better color temp. but the light output isn't the greatest.
Yes, Ive checked out their offerings except it did not show me that as an option when i selected my vehicle. Only the Osram and Morimoto branded D3S are shown.
Im going to give the Osram CBI a chance. Hopefully they add more light output than the replacement D3S bulbs from Dan.
Edited by zayg1994
Yes, but it is a slight difference.
