engine coolant tempreture gauge reading abnormal
Hopefully just a bad cylinder head temperature sensor, and not an actual cooling system issue. Check coolant and engine oil level/condition carefully first. Then you will have to take off the upper AND lower intake manifolds to get to the sensor. Some people have had the wire to this sensor chewed through by pests also.
Many thanks for your kindly reply. I appreciate. I will check as you said.
