DEFROST PROBLEMS!!
Do you have dual zone climate control? Do you have the Sony system installed or no? There are two types of calibration procedures you can perform to "reset" the module, depending on the configuration in your Edge. Hopefully the calibration will do the trick, at least for now.
http://www.fordedgeforum.com/topic/23097-2014-edge-limited-no-heat/
I am having the same issue with my 2010 Edge Limited. I have the Dual Control but not the Sony System. It does have the Microsoft Sync system. When I run the self test I get "A2 6E" in the display. I cannot find what this means. There is a buzzing sound for about 20 seconds whenever I first turn the vehicle on unless I turn the heat off prior to shutting the vehicle off.
