2010 water pump replacement
dat2109
1 hour ago, enigma-2 said:
My local dealer always changes the timing chains and installs the new type guides. Says they are designed to take up slack but are stretched nonetheless and need changing.
He drops the entire powertrain subassembly as its faster. (When I talked to them about it, believe they quoted around $1800).
Talked about having it done as a preventive maintenance item and he said he'd recommend around 175,000 miles. Pumps they see failing are do to poor maintenance.
I wonder what he means by poor maintenance ... is it not a frequent, non-regular coolant change?
