Antoniorivera Posted October 16, 2017 Report Share Posted October 16, 2017 Cooling fans not turning on causing overheating already replaced fuses checked relay and replaced thermostat but can't find relay switch where is it located Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 16, 2017 Report Share Posted October 16, 2017 Common failure. I replaced the fan assembly on my 09, last year (still under extended warranty). You are going to need to replace the fan assembly (consists of both fans, support platform and fan controller). Whether you do it yourself (15 minutes, but you will need to get the car in the air), or have a garage do it, go with Motorcraft. Aftermarket have reported problems. Motorcraft runs about $220 w/o tow pkg, $260 with factory tow pkg. 2 Quote Link to comment Share on other sites More sharing options...
akirby Posted October 17, 2017 Report Share Posted October 17, 2017 Replace the fans with OEM parts. There is a good write up that should be pinned. If not use the search function. 2 Quote Link to comment Share on other sites More sharing options...
