Intranetsites Posted October 14, 2017 Report Share Posted October 14, 2017 (edited) Can anyone suggest a Forscan scanner for my 2017 Ford Edge 2 liter. Problem : currently my cell phone loses its charge during in car use and does not recharge when im out of my vehicle as the usb power is turned off 15 minutes after vehicle is turned off. I have dedicated a Samsung S5 cell phone to be permanently attached to my usb port in my 2017 Edge. I want adjust the delay of power off of the interior accessories from the default 15 minutes to 45 minutes so my always plugged Cell phone is charged or is maintained. I understand that I may be able to change the value founpermanentlyd at BCM 07-39-01 If it is possibly that I can do this myself would be great..... it is way too much time to take this to dealer to adjust. This will probably require resetting the power off delay value many times to findicate the optimium setting. I will test the time delay settings to confirm it will adequately charge the phone. So I will try setting 45 mins at first and ten 1.5 hours and then 3 hours if that is what it takes to charge my phone. Ironically in my 2014 escape the power to the cigarette lighters never turns off. Now that was another problem for some high amp accessories like my weboost cell phone booster would kill my battery over 24 hours of non use. A power delay off function on at least one port would have been appreciated. Edited October 14, 2017 by Intranetsites Quote Link to comment Share on other sites More sharing options...
candurin Posted October 14, 2017 Report Share Posted October 14, 2017 That BCM block is for the 12v power ports/points, NOT the USB. Changing the values in APIM blue back 7D0-01-01 will leave the stereo on after you turn off the car for a longer period (which, in turn, controls the USB power). But, it's a moot point if you open the door. https://docs.google.com/spreadsheets/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/htmlview# If money is no object, buy this OBD tool: https://www.amazon.com/gp/product/B006NZTZLQ If you want HS/MS and money is an issue: https://www.amazon.com/gp/product/B01F0GVBWY I use this one. It gives me access to all the modules I need to access: https://www.amazon.com/gp/product/B005NLQAHS 1 Quote Link to comment Share on other sites More sharing options...
Intranetsites Posted October 22, 2017 Author Report Share Posted October 22, 2017 Thank you:) Quote Link to comment Share on other sites More sharing options...
