2011 Ford Edge backup camera troubles
Does anyone know the proper replacement backup camera? My part number is: DT4T-19G490-AA. i've tried ebay OEM and it was upside down. They sent a BT4Z-19G490-B. I can't find the proper replacement number for the older camera. 2013 Ford EDGE SEL
Edited by bcarl
Per the dealer site, based on the production date of your Edge:
1 BT4Z-19G490-B Rear Camera, TO 10/ 23/ 12
$491.18 $338.92
1 ET4Z-19G490-A Rear Camera, FROM 10/ 24/ 12
$458.65 $316.47
There are people selling on eBay with the OEM moniker just to catch people searching for Original Equipment Manufacturer parts, yes, they are wily that way. Always look for the brand specified in the product description. If it does not stay Ford or Motorcraft, steer clear.
Can you provide a link to the product you purchased? I want to see exactly what they describe. TIA.
BTW, you CAN use a Gen 2 camera F2GZ-19G490-A instead, it just will not calibrate/provide the guidelines, but works perfectly otherwise. A much cheaper option.
Edited by WWWPerfA_ZN0W
