Intranetsites Posted October 8, 2017 Report Share Posted October 8, 2017 (edited) Trying to charge my cell phone overnight in car I understand this setting can be adjusted to allow the USB's to stay on in the front cubby hole after power is off. Currently, all interior power shuts down after 15 minutes Edited October 8, 2017 by Intranetsites Quote Link to comment Share on other sites More sharing options...
lildisco Posted October 8, 2017 Report Share Posted October 8, 2017 Invest in a OBD2 reader & FORScan Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 8, 2017 Report Share Posted October 8, 2017 (edited) Read somewhere (forget where) that there is a BCM setting the dealer can change to disable the timeout so that the 12 volt power points will stay on all the time. Don't know if this works for the USBs however. You could consider adding you own always-on USB ports however. https://www.amazon.com/dp/B00MNGCDVS/ref . Edited October 8, 2017 by enigma-2 Quote Link to comment Share on other sites More sharing options...
jmr061 Posted October 8, 2017 Report Share Posted October 8, 2017 (edited) The USB ports are connected to and controlled by SYNC. SYNC has to be on for them to supply power. They DO NOT work in conjunction with the 12 volt power points. Edited October 8, 2017 by jmr061 1 Quote Link to comment Share on other sites More sharing options...
