Does anybody have access to the mirror wiring schematic?
I originally thought I had a bad mirror motor, then possibly a bad switch on the drivers door. Testing has proven that both the mirror motors and the switch are functional.
It SHOULD be easy to trace the problem, but... the wire colors in the passenger mirror housing and the colors on the back of the control in the drivers door don't match!
First off, I purchased the car used from a dealer, but the history shows only one owner previous. That being said it's possible something happened along the way and one of the doors could have been replaced. I know at a minimum i have at least two connectors to trace through, one at each door hinge. I'm betting there is something in between it goes through since the wire colors change.
BTW, I found a diagram for an older model, but it had three wires at each mirror. I have four, two for up / down and two for left / right.
Left mirror is 100%, right is 50%. Have up / down but no left / right. Putting the control in my F-150 shows it working 100%. Temp connection gets left / right functioning so it's in the wiring.
Thanks for the link, I'm new to the forum. Will dive into it this weekend if I have time.
Okay, so as far as I know my Edge does NOT have the memory function, but the wiring looks to match the one that does.
Having said that, Where is the drivers seat module ( DSM ), and what does it look like? First blush I would say somewhere in the vicinity of the drivers seat, but that would make too much sense.
