NoisverWen Posted October 5, 2017 Report Share Posted October 5, 2017 Hi, I am trying to install ford OEM remote starter on my 2017 ford edge push start. I bought a kit from a ford dealership on ebay which includes the VSS, antenna, and the key fob. After some research and looking under the hood I believe I still need a hood pin. However, I cant figure out where the harness for the hood pin is located. Where should it be? After google searching, most people seem to be able to just pop it in without any trouble. I dont know why I am not seeing it. Would I need to install the harness too? I am beginning to feel like the dealer will need to install this. Thanks! Quote Link to comment Share on other sites More sharing options...
vega Posted October 5, 2017 Report Share Posted October 5, 2017 Open your hood and start the car. If it says your hood is open or ajar, you have the pin and you don't need to do anything further. The remote start just needs to have one present in order to work correctly. (I think all our Edge's have one. At least 2015 forward) As to the remote install, I did mine myself. The hardest thing was removing the cowling under the steering column and disconnecting and reconnecting the pigtail connectors. Need small hands and lots of patience. Although not for the Ford OEM remote start, this video was for mine and was instructive. https://www.youtube.com/watch?v=fB3j7hCHYLg 1 Quote Link to comment Share on other sites More sharing options...
NoisverWen Posted October 5, 2017 Author Report Share Posted October 5, 2017 No hood ajar message, so I dont have a hood pin or if I do have it then its not working. Where should it be located under the hood? I'm not seeing it in ford diagrams and when I search ford accessories a hood pin doesn't come up. Is it somehow connected to the latch? Quote Link to comment Share on other sites More sharing options...
akirby Posted October 5, 2017 Report Share Posted October 5, 2017 It's in the latch. Quote Link to comment Share on other sites More sharing options...
NoisverWen Posted October 6, 2017 Author Report Share Posted October 6, 2017 So I obviously didn't think this through. I hooked up the ford oem remote starter then went to the stealership to have them fix the hood ajar sensor issue and activate my remote start. I figured the repair would be under warranty and I would get both done at the same time. NOPE. They charged me $120 just for the sensor because they said I damaged the hood ajar sensor when I put in the remote starter. Quote Link to comment Share on other sites More sharing options...
jmr061 Posted October 7, 2017 Report Share Posted October 7, 2017 The hood ajar function isn't enabled unless the vehicle has an alarm and/or remote start from factory. Take a look at your hood latch. Does it have an electrical connector plugged into it? That is where the hood switch is located. It is built into the latch. I would assume (yes big assumption) that all levels of the Edge have this even if the base ones that wouldn't come with alarm/remote start. No dealer is going to cover the programming of remote start/alarm under warranty. There was probably nothing wrong with the hood switch circuit. They are juts giving you an excuse to justify the charge which most would charge one hour min labor anyway. 1 Quote Link to comment Share on other sites More sharing options...
candurin Posted October 9, 2017 Report Share Posted October 9, 2017 You'll need to enable hood switch function via IDS (at the dealer) or you can do so via forscan. Quote Link to comment Share on other sites More sharing options...
vega Posted October 10, 2017 Report Share Posted October 10, 2017 The hood ajar function isn't enabled unless the vehicle has an alarm and/or remote start from factory. Take a look at your hood latch. Does it have an electrical connector plugged into it? That is where the hood switch is located. It is built into the latch. I would assume (yes big assumption) that all levels of the Edge have this even if the base ones that wouldn't come with alarm/remote start. No dealer is going to cover the programming of remote start/alarm under warranty. There was probably nothing wrong with the hood switch circuit. They are juts giving you an excuse to justify the charge which most would charge one hour min labor anyway. I have a 2015 se model and have a hoodswitch. I have no remote anything or alarm. If my hood is not latched I get a warning on my display. My point being it may be year specific. Quote Link to comment Share on other sites More sharing options...
ckidwell Posted September 7, 2018 Report Share Posted September 7, 2018 Im having trouble finding where to plug my hood switch in, could you take a photo of yours so I can see where it goes? Quote Link to comment Share on other sites More sharing options...
munchkin Posted September 8, 2018 Report Share Posted September 8, 2018 Could you tell me how to do this? I'm having trouble with a lot of the technical aspects but remote start was one of my must haves and the edge I finally decided on doesn't have it but I knew I could add it later. I would much prefer to program it into my existing fob than have to carry an additional fob around. Quote Link to comment Share on other sites More sharing options...
Guest Hippy Posted December 10, 2018 Report Share Posted December 10, 2018 Im doing the same thing... Look at hood latch and see if there are wires going to it...per an earlier response. Turning it on via computer is the key aspect. Quote Link to comment Share on other sites More sharing options...
Menthol Posted May 20, 2019 Report Share Posted May 20, 2019 On 10/9/2017 at 5:34 PM, candurin said: You'll need to enable hood switch function via IDS (at the dealer) or you can do so via forscan. Can you enable remote start thru forscan too or only thru IDS (dealer)? Quote Link to comment Share on other sites More sharing options...
candurin Posted May 20, 2019 Report Share Posted May 20, 2019 (edited) It can be done with FORScan. It’s under the BCM settings. Edited May 21, 2019 by candurin Quote Link to comment Share on other sites More sharing options...
Menthol Posted May 21, 2019 Report Share Posted May 21, 2019 (edited) 2 hours ago, candurin said: It can be done under remote scan. It’s under the BCM settings Thks Edited May 21, 2019 by Menthol Quote Link to comment Share on other sites More sharing options...
