blowenblu Posted October 4, 2017 Report Share Posted October 4, 2017 Need some help, On my 2011 Edge I have a bad #4 Fuel Injector (Front left). Can I replace this 1 without removing intake manifold? Not sure if fuel rail is one piece connecting to back injectors or if I can just remove fuel rail from front injectors. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 4, 2017 Report Share Posted October 4, 2017 No. Unfortunately, the intake manifold has to be removed to replace ANY fuel injector. The rail and injectors are removed as an "assembly". Quote Link to comment Share on other sites More sharing options...
macbwt Posted October 5, 2017 Report Share Posted October 5, 2017 If you are going to replace the injectors you may as well replace the plugs and rotate the coils. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted October 5, 2017 Report Share Posted October 5, 2017 First thing you have to double check is are you sure the injector is bad? Not that it is not possible but injector failure is not a big issue with the Duratec. Plugs and coils are. 1 Quote Link to comment Share on other sites More sharing options...
