037 Posted March 13, 2018 Report Share Posted March 13, 2018 K, Ford is not Audi and S4 is not an Edge. Quote Link to comment Share on other sites More sharing options...
Special_K Posted March 13, 2018 Report Share Posted March 13, 2018 K, Ford is not Audi and S4 is not an Edge. Well that explains a lot, i get them confused very easily, thanks for clarifying that for me . I am just speaking from my experience in vehicles. Also, wheel hop will of occur at some point with any car when increasing power, its the nature of the beast. Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted March 13, 2018 Report Share Posted March 13, 2018 K, Ford is not Audi and S4 is not an Edge. Think he was referring more to, Quattro vs Edge's poor mans AWD system 3 Quote Link to comment Share on other sites More sharing options...
Special_K Posted March 13, 2018 Report Share Posted March 13, 2018 UPDATE: #turboporn Same exducer size, different inducer to achieve no turbo lag and higher boost up top! 2 Quote Link to comment Share on other sites More sharing options...
Mikula Posted March 13, 2018 Report Share Posted March 13, 2018 I have yet to encounter any wheel hop either, just a lot slower times than leo. Then again, I don't launch with my right foot on the floor either. Quote Link to comment Share on other sites More sharing options...
037 Posted March 14, 2018 Report Share Posted March 14, 2018 The car has 12.6s in it if I wasn't hopping, I have yet to max it out :-) 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 14, 2018 Report Share Posted March 14, 2018 What email addy did you send your requests to? I confirmed with him that torrie@unleashedtuning.com is the correct contact. If you PM me your addy, I will ask him to look out for your communications. On a disappointing note, Torrie from unleashed has yet to reply to any of my emails so we maybe stuck finding a different tuner :-/ 1 Quote Link to comment Share on other sites More sharing options...
Special_K Posted March 14, 2018 Report Share Posted March 14, 2018 What email addy did you send your requests to? I confirmed with him that torrie@unleashedtuning.com is the correct contact. If you PM me your addy, I will ask him to look out for your communications. Leslie got back in touch with us. So we have the tuner on board, turbos are being wrapped up, boost noodle is being fabricated, BOV is in the mail, Turbo blankets are being made, and it seems the only hold up is CP-e with the intercooler :-/ STAY TUNED 2 Quote Link to comment Share on other sites More sharing options...
One Slow 5.0 Posted March 14, 2018 Report Share Posted March 14, 2018 Where did you get the turbo blankets made? Quote Link to comment Share on other sites More sharing options...
Special_K Posted March 14, 2018 Report Share Posted March 14, 2018 Where did you get the turbo blankets made? PTP Quote Link to comment Share on other sites More sharing options...
atekido Posted March 15, 2018 Report Share Posted March 15, 2018 Just curious isn't our PTU on the AWD a huge weak point already? From so many threads on here i figured this type of power gains would basically just be to much for the PTU. Or is the PTU not quite as unreliable as some have made it out to be on here? 1 Quote Link to comment Share on other sites More sharing options...
Special_K Posted March 15, 2018 Report Share Posted March 15, 2018 Just curious isn't our PTU on the AWD a huge weak point already? From so many threads on here i figured this type of power gains would basically just be to much for the PTU. Or is the PTU not quite as unreliable as some have made it out to be on here? you are correct the PTU is a limiting factor. however the Gen 2 Edgesport uses the same ptu out of the explorer which gives us a little bit of head room. Everything has its limits of course. Quote Link to comment Share on other sites More sharing options...
atekido Posted March 15, 2018 Report Share Posted March 15, 2018 oh gotcha. didn't realize the change in PTU for the gen2. well monkey balls! lol Quote Link to comment Share on other sites More sharing options...
Special_K Posted March 15, 2018 Report Share Posted March 15, 2018 oh gotcha. didn't realize the change in PTU for the gen2. well monkey balls! lol All good! we are all here to learn and have fun! Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted March 15, 2018 Report Share Posted March 15, 2018 Just curious isn't our PTU on the AWD a huge weak point already? From so many threads on here i figured this type of power gains would basically just be to much for the PTU. Or is the PTU not quite as unreliable as some have made it out to be on here? Fords PTU across the board is a weak point, no matter the chassis it's on. The beauty of it this time in 2nd gen, it's actually serviceable 2 Quote Link to comment Share on other sites More sharing options...
macbwt Posted March 16, 2018 Report Share Posted March 16, 2018 Just curious isn't our PTU on the AWD a huge weak point already? From so many threads on here i figured this type of power gains would basically just be to much for the PTU. Or is the PTU not quite as unreliable as some have made it out to be on here? I have done a fair amount of Gear lube testing and think I have found the best Gear lube to use with the PTU. Frequency of change is the key to longevity plus the extra amount of capacity that has been added to the PTU are the slight improvements with the addition of a drain plug to facilitate fluid changes. The PTU should be able to handle up to about 500hp. The newer PTU's have had some additional internal adjustments but heat is still the enemy of the lubricants. 1 Quote Link to comment Share on other sites More sharing options...
Special_K Posted March 16, 2018 Report Share Posted March 16, 2018 I have done a fair amount of Gear lube testing and think I have found the best Gear lube to use with the PTU. Frequency of change is the key to longevity plus the extra amount of capacity that has been added to the PTU are the slight improvements with the addition of a drain plug to facilitate fluid changes. The PTU should be able to handle up to about 500hp. The newer PTU's have had some additional internal adjustments but heat is still the enemy of the lubricants. Awesome info! Would you like to enlighten what the best Gear lube is?? 1 Quote Link to comment Share on other sites More sharing options...
atekido Posted March 16, 2018 Report Share Posted March 16, 2018 Makes me wish I had waited for a 2016+ edge instead of grabbing a 2015 lol. Quote Link to comment Share on other sites More sharing options...
Special_K Posted March 16, 2018 Report Share Posted March 16, 2018 Makes me wish I had waited for a 2016+ edge instead of grabbing a 2015 lol. time to trade in ;-) Quote Link to comment Share on other sites More sharing options...
macbwt Posted March 16, 2018 Report Share Posted March 16, 2018 Awesome info! Would you like to enlighten what the best Gear lube is?? I will in the near future. Spent a lot of time and money making the oil series videos for my channel. The series will be complete by the 2nd week of April with a full summary of all the oils tested and gear lubes tested. Frequency is VERY important. 1 Quote Link to comment Share on other sites More sharing options...
037 Posted March 16, 2018 Report Share Posted March 16, 2018 Makes me wish I had waited for a 2016+ edge instead of grabbing a 2015 lol. 2015 Handles 450hp and over 500 tq just fine, at least at 18000 miles. 1 Quote Link to comment Share on other sites More sharing options...
Xtra Posted March 16, 2018 Report Share Posted March 16, 2018 snmjim, when these performance turbos become available will we need to send in our turbos for the core. Or will they be offered complete ? If a core is needed where did you find your used turbos for $300 or was it $300 each? 1 Quote Link to comment Share on other sites More sharing options...
snmjim Posted March 16, 2018 Author Report Share Posted March 16, 2018 snmjim, when these performance turbos become available will we need to send in our turbos for the core. Or will they be offered complete ? If a core is needed where did you find your used turbos for $300 or was it $300 each? We are sending the cores off our car after we install the modified ones. So hopefully they will be available with core exchange. 2 Quote Link to comment Share on other sites More sharing options...
Xtra Posted March 17, 2018 Report Share Posted March 17, 2018 We are sending the cores off our car after we install the modified ones. So hopefully they will be available with core exchange. I want to keep my stock turbos so where did you get your used turbos? Quote Link to comment Share on other sites More sharing options...
snmjim Posted March 17, 2018 Author Report Share Posted March 17, 2018 www.car-part.com Also try www.partrequest.com 2 Quote Link to comment Share on other sites More sharing options...
