2014 edge front body mounts
Is there a way to replace the front body mounts on a 2014 edge? I am able to access the bottom nut but it appears the top nut/bolt is not accessable?
My in laws purchased their 2014 edge from an individual that rebuilt the car and it was wrecked in the front passenger side. A lot of parts were replaced on the front end. The person who repaired it did not replace the passenger side body mount. When I jack up that side of the car, I can see and hear the body mount move when there is a load placed on it. It also makes noise when backing up and turning. The bolt for the body mount is crooked so that means it is bent somewhere. They tried to install large washers to compensate for the crooked body mount bolt but it is not working.
I couldnt find an access point to get to the top of the body mount bolt, so I am un sure if they can even be replaced?
See here
https://www.fordpartsgiant.com/parts-list/2014-ford-edge/chassis-frame.html
Ford BT4Z-5400145-A
BT4Z-5400145-A
Shim
Washer - Insulating
Require Quantity: 2
Package Quantity: 1
Base Number: <00145A
Callout Name: <00145A
$15.95$11.20
Ford 5F9Z-5400145-AA
5F9Z-5400145-AA
Shim
Reinforcement
Require Quantity: 2
Package Quantity: 1
Base Number: <00145
Callout Name: <00145B
$8.18$5.74
https://parts.levittownfordparts.com/auto-parts/2013/ford/edge/sel-trim/3-5l-v6-gas-engine/front-suspension-cat/suspension-components-scat
No. Part # Description List Price Price
1 BT4Z-3K185-A Knuckle
Knuckle, RIGHT
$119.69 $75.70
1 BT4Z-3K186-A Knuckle
Knuckle, LEFT
$119.69 $75.70
2 -W714681-S439 Knuckle Bolt
Knuckle Bolt, RIGHT
$2.78 $1.60
Knuckle Bolt, LEFT
$2.78 $1.60
3 -W520213-S440 Stabilizer Bar Nut
Knuckle Nut, LEFT
$4.63 $2.67
Knuckle Nut, RIGHT
$4.63 $2.67
4 8T4Z-3079-A Lower Control Arm
Lower Control Arm, LEFT
$255.38 $161.53
4 8T4Z-3078-A Lower Control Arm
Lower Control Arm, RIGHT
$255.38 $161.53
5 -W712734-S439 Lower Control Arm Bolt
Lower Control Arm Bolt, LEFT
$4.25 $2.45
Lower Control Arm Bolt, RIGHT
$4.25 $2.45
6 -W712850-S439 Lower Control Arm Mount Bolt
Lower Control Arm Mount Bolt, LEFT
$2.13 $1.22
Lower Control Arm Mount Bolt, RIGHT
$2.13 $1.22
8 BT4Z-5482-A Stabilizer Bar
W/ O 22 WHEELS
$119.43 $82.41
8 7T4Z-5482-B Stabilizer Bar
W/ 22 WHEELS
$184.92 $127.59
9 7T4Z-5484-B Stabilizer Bar Bushing
Stabilizer Bar Bushing, LEFT
W/ AWD
$14.68 $10.13
9 7T4Z-5484-A Stabilizer Bar Bushing
W/ O AWD
$15.15 $10.45
Stabilizer Bar Bushing, RIGHT
W/ O AWD
$15.15 $10.45
W/ AWD
$14.68 $10.13
10 7T4Z-5486-AA Stabilizer Bar Bracket
Stabilizer Bar Bracket, RIGHT
$23.02 $15.88
Stabilizer Bar Bracket, LEFT
$23.02 $15.88
11 -W712802-S439 Stabilizer Bar Bolt
Stabilizer Bar Bolt, LEFT
$1.00 $0.58
Stabilizer Bar Bolt, RIGHT
$1.00 $0.58
12 7T4Z-5K483-A Stabilizer Link
Stabilizer Link, LEFT
$44.29 $28.01
Stabilizer Link, RIGHT
$44.29 $28.01
13 -W520214-S440 Control Arm Lock Nut
Stabilizer Link Nut, LEFT
$5.97 $3.44
Stabilizer Link Nut, RIGHT
$5.97 $3.44
14 7T4Z-3B154-AL Mount Plate
Mount Plate, LEFT
$19.83 $13.69
14 7T4Z-3B154-AR Mount Plate
Mount Plate, RIGHT
$19.83 $13.69
15 9T4Z-5874-A Stabilizer
$94.33 $65.09
16 DT4Z-5C145-A Engine Cradle
FROM 2/ 15/ 12
$875.50 $604.10
17 7T4Z-5400155-AB Engine Cradle Insulator
Engine Cradle Upper Insulator, LEFT
$17.30 $11.94
Engine Cradle Upper Insulator, RIGHT
$17.30 $11.94
18 BT4Z-5400155-A Engine Cradle Insulator
Engine Cradle Lower Insulator, LEFT
$15.68 $10.82
Engine Cradle Lower Insulator, RIGHT
$15.68 $10.82
19 DT4Z-5019-A Cross-Member
FROM 2/ 15/ 12
$68.62 $47.35
Edited by WWWPerfA_ZN0W
