Comprehensive List of Possible Forscan Mods?
ben senise
  On 12/30/2018 at 1:48 PM, matt8686 said:
yes, but it resets with each engine cycle. i've had the car for 2 days and am already annoyed the times i forget to push the button and it shuts off at a red light.
Expand
Ahh ok. I can see it getting annoying too. Right now I just anticipate the light going green and let off the brake early so it restarts. In traffic I just brake enough to stop and it won’t shut off. I’ll be watching for your solution in case it becomes too aggravating.
i have read that keeping the vehicle in sport mode also eliminates the feature, but i'm not sure i'd like to drive in sport 100% of the time. the ForScan fix should work.. i am just trying to be cautious and get as much info as possible before manipulating my vehicle's software. i will update.
Expand
Sport mode has the same problem as just deactivating  start/stop with the button. It defaults back to non sport every time you turn off the car.
Edited by Fingernip
  • 4 weeks later...
  On 2/26/2018 at 6:15 AM, cv27 said:
On Sync2, the following Mod does not work:
APIM 7D0-01-01 xxxx xxxx x7xx Heated Seat AND Steering Wheel on home & climate screen
Given the right package, the 8" display on Sync2 will show by default heated and AC seat buttons, as well as the heated steering wheel.
When this Mod is applied, AC seat icons are removed from the home screen.
Expand
I believ x6xx will show heated and AC seat buttons, as well as the heated steering wheel.
I was able to drive around in a loaner 2019 SEL.  The SYNC system was v3.3 (which is 2018 and newer APIM with larger memory partition).
I noticed that when I change the temperature in the car, a rotary indication was displayed in the screen indicating my temp set point.  I'd love to see if I can get this on my SYNC 3 upgrade.
Can anyone with a 2017 or newer model year confirm if you have this indicator or not?  I have a feeling it is only available on 2018 MY or newer (v3.2 hardware or higher).
Expand
I have it on my 2017.
Expand
I have it on my Edge ST.  It does the same when you change the volume.
Hmmm.  I wonder if it’s related to the firmware in my FCIM.  Because the “rest” of my car is a 2012, I don’t have the rotary temp indicator.
Ill have to see if there is an apim setting in forscan I’m overlooking.
thanks all.
edit:  tried every related setting change with FORScan and no go.  Oh well.  Something to look forward to when I finally cave and buy a new MY.
Edited by candurin
thanks all.
Expand
Drop me a line if you decide to pull your sync 3 set up.
  On 2/1/2019 at 11:45 PM, candurin said:
I certainly will.  It won’t be for awhile, though..  Just put new wheels, tires and HID bulbs (old ones were almost 7 years old and getting dim).  Car only has 77k miles!
Expand
Take your time.  My lady is interested but she doesn't seem overly pressed  about it.  Then again she has her eye on my sport so go figure.   There are a couple of things that bother me with the ST. Then again there were things that bothered me with the 2nd gen yet here I am.  I'm sure the ST will grow on me.
I have checked out this entire discussion on forscan mods and did not see anyone mention anything about start/stop. Please... does anyone know how to disable this feature. I have tried to "get used to it" but it's a no go. Just too annoying. Additionally is there any way to stop the outside vehicle lights from coming on every time I open a door? I have a 2019 Edge Titanium with 301.
Thank you all for any help with this.
Expand
https://forscan.org/forum/viewtopic.php?t=3218
This seems to work for a variety of Ford vehicles.
  On 2/22/2018 at 7:44 PM, Nois3 said:
So I didn't get to go through the whole thread but I might be able to answer some questions and help out with the Forscan mods on the Edge. I got 2016 Sport 400A package. So far I did the following:
Disable DRLs (for HIDs to work)
Reverse mirror tilt
Global window close (Open was enabled from factory)
Disabled hyperflash (for my front LED turn signals)
Disabled front lamp outage (for HIDs to work)
Enabled secure idle (lock the shifter when fob is not in car while car is running)
Disabled double horn honk
Enabled heated SW and seats buttons on home screen on Sync
Enabled climate section on right cluster screen
Added fuel history display
Added hill start assist (haven't tested it yet)
Now here is my to do list that I am trying to figure out. If anyone has any ideas please let me know:
- Disable stability control (AdvanceTrac) for some fun in the snow
- Enable Auto hold (for the car to auto hold the brakes on a long traffic light)
- Disable "Language Set To English" prompt on every start when I enable the View Text Msgs/Nav Keyboard while in motion
If anyone wants the codes for the mods i've done, let me know.
Expand
Do you have a ESC button on your dash to turn on and off traction control?  If so try holding the button for over 5 seconds and see if that turns off the AdvanceTrac.  It does on the 2019, I got the idea from my 2016 Focus ST I had where you could put it in Track Mode by holding the button.  On the Edge ST it turns off the AdvanceTrac totally disabling both traction control and the ESC so you can slide around.  The 2019 has a Sport mode but that for some reason leaves the traction control on but allows a little more side to side movement.  Unlike on the Focus where it allows wheel spin and lessens the nannies to allow a little sliding around if you cornered hard.  Anyway it is worth a try to see if it turns off AdvanceTrac.
CONFIRMED: THIS WORKED FOR A 2019 EDGE TITANIUM WITH 301A PKG.
Auto start stop disabled using:  BdyCM module - 726-48-02   X1XX XXXX  By changing the one to a zero  >>>   X0XX XXXX
Additionally changed the turn signal 3 flash to a 5 flash using:  SCCM module -  724-01-01   XXXX X7XX   By changing the seven to a B  >>>   XXXX XBXX
This is the adapter I used. Thanks to all that have helped with this. Hope this helps others...  $30. for the adapter.
OHP ELMconfig Forscan OBD2 Adapter with MS-Can & HS-Can Switch for Ford DIY Diagnostics on Windows - Link below
https://www.amazon.com/gp/product/B01F0GVBWY/ref=ppx_yo_dt_b_asin_title_o00__o00_s00?ie=UTF8&psc=1
Expand
Glad it worked!
  On 2/16/2019 at 4:30 AM, Dsmtweaker said:
Anyone know how to keep the drl led accents lights(ford signature lighting) on While using turn signal?
Expand
I don't see any specific directions for 'signature lighting'. There are some posts about trying to disable them (they had no luck there).
If present, the setting would probably be in the BCM module (726). You'd need to find a listing of all the codes, then compare to your AsBuild listing to find address that aren't described/discovered. My AsBuild (401A) goes to 726-74-02  (F-150 goes to 726-74-02 see that page).
Bothers me too but I only see it when there is a reflection from a car in front of me.
Also called 'Winking'. Most vehicles do this.
