Comprehensive List of Possible Forscan Mods?
ben senise
  • 4 weeks later...
Question guys.
I haven’t done any forscan mods in awhile, but I just noticed this. Yesterday I drove to work with the windows down, so climate control off. Remote started before leaving work to have the AC cool it down. Got in the car and the climate control was off.
Now I usually have it set in the IPC menu to have the climate control and climate seats on “auto” rather than “last setting” during remote start. Went to change it back, and it’s greyed out in the menu.
Anyone know where to re enable it?
Edited by tmarsh
1 hour ago, tmarsh said:
Question guys.
5 hours ago, tmarsh said:
Question guys.
There was a message on it with Ford foe a fix. Though it seems what @onyxbfly suggested might be a similar fix.
https://ford.oemdtc.com/3616/remote-start-selections-grayed-out-for-heated-steering-wheel-heated-seats-2015-2018-ford-edge-2016-2018-lincoln-mkx
Question guys.
are you saying that the climate control was not functioning or just that you didn't see it displayed on the panel?
i have noticed that when remote starting the car, the various indicators like seat heating and AC don't light up but the seats are warm or the AC is working. it's bizarre and i've wondered why this is so but it is what it is.
I believe he is referring to the remote start menu on the left IPC.
Vehicle-->Remote start-->Climate Control--> Auto / last setting
That menu seems to be greyed out now and not accessible.
Yes, exactly. I no longer have the ability to tell the climate control and seats what to do during remote start. What is annoying, is now they do nothing. Even with auto as the last setting when I turn off the ignition, when I remote start the climate control doesn't turn on at all. It won't let me load a picture, but its on the left screen in settings>vehicle>remote start> and the options for climate control and seats are greyed out.
Edited by tmarsh
24 minutes ago, tmarsh said:
Yes, exactly. I no longer have the ability to tell the climate control and seats what to do during remote start. What is annoying, is now they do nothing. Even with auto as the last setting when I turn off the ignition, when I remote start the climate control doesn't turn on at all. It won't let me load a picture, but its on the left screen in settings>vehicle>remote start> and the options for climate control and seats are grayed out.
Try these Forscan codes:
720-02-02 (2013+ MY) xxxx XXxx
(IPC) 00 (Disabled)
  AA (Enabled - Vehicle Without Heated Seats)
  FA (Enabled w/Climate Control) - 2013-2014
  FD (Enabled w/Climate Control) - 2015+
FE (Enabled w/Climate Control and Heated Steering Wheel)
720-02-02 xxxx *xxx   Rem Start - Climate Settings (RSCS), Rem Start -Driver Seat (RSD), Rem Start - Feature (RSF), Rem Start - Pass Seat (RSPS)
0=RSCS disabled, RSD disabled, RSF disabled, RSPS disabled 8=RSCS enabled, RSD disabled, RSF disabled, RSPS disabled
1=RSCS disabled, RSD disabled, RSF disabled, RSPS enabled 9=RSCS enabled, RSD disabled, RSF disabled, RSPS enabled
2=RSCS disabled, RSD disabled, RSF enabled, RSPS disabled A=RSCS enabled, RSD disabled, RSF enabled, RSPS disabled
3=RSCS disabled, RSD disabled, RSF enabled, RSPS enabled B=RSCS enabled, RSD disabled, RSF enabled, RSPS enabled
4=RSCS disabled, RSD enabled, RSF disabled, RSPS disabled C=RSCS enabled, RSD enabled, RSF disabled, RSPS disabled
5=RSCS disabled, RSD enabled, RSF disabled, RSPS enabled D=RSCS enabled, RSD enabled, RSF disabled, RSPS enabled
6=RSCS disabled, RSD enabled, RSF enabled, RSPS disabled E=RSCS enabled, RSD enabled, RSF enabled, RSPS disabled
7=RSCS disabled, RSD enabled, RSF enabled, RSPS enabled F=RSCS enabled, RSD enabled, RSF enabled, RSPS enabled
720-02-02 xxxx x*xx
Rem Start - Rear Defrost (RSRD), Rem Start - Steering Wheel (RSSW), Not In Park (NIP)
0=RSRD disabled, RSSW disabled, NIP disabled A=RSRD enabled, RSSW disabled, NIP disabled
1=RSRD disabled, RSSW disabled, NIP enabled B=RSRD enabled, RSSW disabled, NIP enabled
6=RSRD disabled, RSSW enabled, NIP disabled C=RSRD enabled, RSSW enabled, NIP disabled
7=RSRD disabled, RSSW enabled, NIP enabled D=RSRD enabled, RSSW enabled, NIP enabled
  • Like 3
okay, got it. thanks. i misunderstood.
ah cool
i think i fixed it.  mislabeled one of my saves.
so far disabled horn honk without key
climate on right gauge
heated cooled seat buttons on main sync
disabled auto stop start
changed alert sounds to gauge instead of speakers
i was trying to load the ford gt dark blue sync 3 theme but it looks like its not there
i am wondering why every time i start the car i get a prompt to connect to a network.  gets annoying.
ah cool
heated steering wheel to 10 min timer
Edited by commbubba19
14 minutes ago, commbubba19 said:
ah cool
I agree... that prompt to connect to network is annoying. I went into setting to disable and a few days later it was back again. Ford  Sync 3 is not well thought out.
I also have a FCA product and the media/info screen is much better. Better graphics... better speed and no on screen prompts that require you press an acknowledgement before it goes away.
After using the Sync 3 for seven months now, I don't like it.
Additionally the right gauge area is useless and could contain more useful info.
BTW... What code did you use to put the climate on the right?
Edited by tk2fast
Turn off both Automatic System Updates (Settings/General Settings/Automatic System Updates)
and
System WiFi (Settings/WiFi/System Wifi)
The WiFi symbol will disappear from the upper notification bar.  Done!
  • 2 months later...
Virgin alert!  lol.  Just picked up my 2019 Ruby Red Titanium Elite w/ 301a on Friday.  Enjoyed reading this post and look forward to playing around with some of these.  Holding off til I take my car back to dealer, so they can do the adaptive headlight update that they forgot(also have a warped windshield).
Was wondering if anyone found out the following;
1)  Disable safety feature of front camera, ie. turn it on while driving.
2)  Enable 1-touch close of sunroof(shade does it, why not the roof?)
I know these are model specific, so might be out of luck
Thanx in advance!
Unfortunately FORScan doesn't offer either of those capabilities.  There 'might' be aftermarket modules that can be plugged into the head unit that would allow the front camera to be turned on.  The funky roof closing is purportedly a safety system to keep people from trapping hands/heads or puppy dogs in the roof while it's closing.
Let me offer a little "starter kit' to save you some trouble hunting up the spreadsheets showing changes that can be made with FORScan.
There's this one on the 2G Fusions site:  https://docs.google.com/spreadsheets/d/1yax6zfhZYj2joBczEeruqKh9X5Qhee3C0ngilqwTA7E/pubhtml?gid=0&single=true
And this one on the Ford F150 site: https://docs.google.com/spreadsheets/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/edit#gid=815852466
They're pretty much the same, just laid out a little differently.  Not all the mods listed will work in your Edge.  Read the entire tutorial so you know how to operate the program: https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit
Let me add my usual caution.  Before making ANY mods, back up your existing AsBuilt data.  Also back up individual modules with FORScan before saving changes.  You should also download your entire AsBuilt file from Ford and save it just in case something goes radically wrong and you have to reset the entire system:  https://www.motorcraftservice.com/asbuilt
Save all those links to a folder in your browser and/or download them to your computer for future reference.
Cheers!
  • Like 3
Thank you kindly @Gadgetjq.  Much appreciated!
Gear # indication.
A while back I drove a rental Expedition and it showed gear position all the time  - is there a way to do the same on the Edge?
If you use the paddles it will briefly display the gear # that its just shifted to - is there an option to have it display gear # at all times?
Edited by 1004ron
