Dukhaykh Posted July 24, 2018 Report Share Posted July 24, 2018 After a lot of searching and testing with ForScan codes, I've come up with these Mods that I have successfully applied them to my 2014 SEL Edge; Car gauge needles Move up & down when car started; (IPC) 720-04-01 xxXx xxxx xxxx 8 (Enabled) -------------------- Door Close Double Horn Honk (Engine Running Without Keyfob Detected (PTS)):(BCM)726-16-01 xxXx zz 0=Disabled1=Enabled (Default) -------------------- Number of Turn Signal Flashes(SCCM)724-01-01 xxxx xXxx zz 0-3=1 Flash, 4-5=2 Flashes, 6-7=3 Flashes, 8,9=4 Flashes, A,B=5 Flashes, C,D=6 Flashes, E,F=7 Flashes ------------------- Dark Mode (No lights when door open)(BCM)726-08-01 xxxX zz0=Disabled, 1=Enabled ------------------- Good Luck 1 Quote Link to comment Share on other sites More sharing options...
NoDTMF Posted July 24, 2018 Report Share Posted July 24, 2018 On 3/22/2018 at 9:53 AM, omar302 said: Did this work for you? So I wasn't looking at this thread for a while. I did not try all the mods, I was just posting ones I had seen. Quote Link to comment Share on other sites More sharing options...
tmarsh Posted July 28, 2018 Report Share Posted July 28, 2018 Has anyone come accross adding gear display while in drive and sport(when not using select shift)? It was mentioned early in this thread but no code or location given. 2 Quote Link to comment Share on other sites More sharing options...
akirby Posted July 28, 2018 Report Share Posted July 28, 2018 That would be a good mod to find, although I think it’s a bit less interesting on a 6 speed. I have it on my 10 speed F150 (normal operation) and it’s cool to see it skip gears when accelerating and see when it’s in 8th 9th or 10th gear when cruising. You use the display to lock out higher gears (for towing) but I leave it on all the time. I wonder if the new 8 speed will have something similar? Quote Link to comment Share on other sites More sharing options...
omar302 Posted July 28, 2018 Report Share Posted July 28, 2018 (edited) As per NoDTMF, it is possible to get the current Gear notification through a tune. https://www.fordedgeforum.com/topic/24624-wanting-an-lms-tune/?do=findComment&comment=188285 Edited July 28, 2018 by omar302 Quote Link to comment Share on other sites More sharing options...
tmarsh Posted July 28, 2018 Report Share Posted July 28, 2018 (edited) On 7/28/2018 at 1:51 PM, omar302 said: As per NoDTMF, it is possible to get the current Gear notification through a tune. https://www.fordedgeforum.com/topic/24624-wanting-an-lms-tune/?do=findComment&comment=188285 Yeah I asked LMS when I requested my tunes, and they said it was only possible with forscan. Seems like a forscan thing to me anyway, its in the IPC. Doesnt really have anything to do with the tuning of the engine. Edited July 28, 2018 by tmarsh 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted July 28, 2018 Report Share Posted July 28, 2018 Maybe someone will be kind enough to request unleashed for the code. Quote Link to comment Share on other sites More sharing options...
DCXP3 Posted July 30, 2018 Report Share Posted July 30, 2018 I successfully disabled the AUTOLOCK feature on 2017 Edge Titanium. Autolock is the feature that automatically locks all doors when the vehicle exceeds 12 mph. (BCM)726-15-01 xXxX xXxX xXxx 0=disable, 1=enable, 2=INOP 1 Quote Link to comment Share on other sites More sharing options...
NoDTMF Posted August 2, 2018 Report Share Posted August 2, 2018 (edited) On 7/28/2018 at 2:30 PM, omar302 said: Maybe someone will be kind enough to request unleashed for the code. It doesn't work that way. HP Tuners somehow figured out the memory location for the gear indicator. I bought the HP Tuner hardware and Unleashed used HP Tuner hardware to tune me remotely (I has to do like 80 WoT runs) So I can see the menu to enable the for Drive ,Sport, Sand, etc. Unleashed just uses HP Tuners to change the parameters. Did LMS give you the Forscan codes? It seems this setting is in the ECU, not seen many Forscan codes for that. Edited August 2, 2018 by NoDTMF 1 Quote Link to comment Share on other sites More sharing options...
tmarsh Posted August 2, 2018 Report Share Posted August 2, 2018 (edited) LMS said they were not able to change it. But they said it was a forscan thing, and no did not give any code for it. The gear only displays in select shift mode in sport, same as stock tune. Edited August 2, 2018 by tmarsh 1 Quote Link to comment Share on other sites More sharing options...
NoDTMF Posted August 6, 2018 Report Share Posted August 6, 2018 Also another thing Ive seen in the tuning software and not in the forscan codes is the setting to leave the grill shutters completely open all the time. I set mine to open all the time. Ford says the shutters are for gas mileage. I got ~22 mpg on a 200 mile trip this weekend of freeway drivway at various speeds and cruise control. 1 Quote Link to comment Share on other sites More sharing options...
ericb49 Posted August 21, 2018 Report Share Posted August 21, 2018 On 2/24/2018 at 5:31 PM, Nois3 said: See the list below for the mods. As for the tails, no mods. Just the baby on board sticker. I attached the list of all mods. The oem values are for my car so use yours. I couldn't post the table here as the forum doesn't like tables. EDIT: Attaching the pdf didn't work as well. Here is a link: https://1drv.ms/b/s!AufAlww3zzXuymY5J1IZ6Cr3Si24 Thanks, this is great. Quote Link to comment Share on other sites More sharing options...
EdgeEh Posted August 23, 2018 Report Share Posted August 23, 2018 Recently owned a 2018 Titanium Edge (Canadian). I disliked the headlamp and upgraded to Sylvania Silverstar, to save some life of the low beam bulb I enabled the DRL control using FORScan. I can confirm it's the same values as Fusion 1) BdyCM 726-16-02 - 0202 0202 024F (Disabled) to 0101 0101 0049 (Enabled) 2) IPC DRL set to Enable 2 Quote Link to comment Share on other sites More sharing options...
tk2fast Posted August 25, 2018 Report Share Posted August 25, 2018 Is there any way to permanently turn off start/stop? Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 25, 2018 Report Share Posted August 25, 2018 On 7/24/2018 at 9:53 AM, Dukhaykh said: After a lot of searching and testing with ForScan codes, I've come up with these Mods that I have successfully applied them to my 2014 SEL Edge; Car gauge needles Move up & down when car started; (IPC) 720-04-01 xxXx xxxx xxxx 8 (Enabled) What was the original value? Tried it on a 2014 Limited Edge but it didn't work. Original value was "3". Quote Link to comment Share on other sites More sharing options...
cv27 Posted September 21, 2018 Report Share Posted September 21, 2018 On 4/27/2018 at 7:10 PM, cv27 said: ForScan: Module Section As built value Updated value Tested Status Parameters Notes APIM 7D0-02-01 4341 0104 E447 x7xx xxxx xxxx 2018-02-25 Enabled Enable view text/nav input while in motion I tried this mod successfully on a 2015 Titanium, but it appears not to work on a 2016 Titanium. Can someone please confirm they were able to do this on a 2016? Quote Link to comment Share on other sites More sharing options...
akirby Posted September 21, 2018 Report Share Posted September 21, 2018 On 8/25/2018 at 5:53 PM, tk2fast said: Is there any way to permanently turn off start/stop? Yes with Forscan. Or some have experimented with changes to the switch wiring with mixed results. Quote Link to comment Share on other sites More sharing options...
ericb49 Posted September 24, 2018 Report Share Posted September 24, 2018 Can I edit the as built I downloaded for my Vin # and upload it to the car via FORscan, rather than editing the values directly in FORscan? Quote Link to comment Share on other sites More sharing options...
redden18 Posted September 26, 2018 Report Share Posted September 26, 2018 On 7/24/2018 at 9:53 AM, Dukhaykh said: ------------------- Dark Mode (No lights when door open)(BCM) 726-08-01 xxxX zz 0=Disabled, 1=Enabled ------------------- Good Luck There is a button now to do that next to glasses holder (at least on 2018MY Ti) 1 Quote Link to comment Share on other sites More sharing options...
redden18 Posted September 26, 2018 Report Share Posted September 26, 2018 I'm enjoing typing an address and viewing messages while driving for a while on my 2012 Explorer, but that is only because I have no Sirius subscription. These two are not compatible with each other! Ford delivered another piece of something in this area. Why I can not have both? I want to enable this feature on my new Edge, but currently I have Sirius subscription including traffic and dont want to loose them. Meanwhile, Sirius Travel Link is pretty much useless in Canada. Fuel prices and movies listings are not working at all. Weather and Ski conditions do not know about Canada at all, only traffic is left. So far, both 5753 and 4741 APIM 7D0-02-01 XXXX xxxx xxxx enable Navi and messages in-motion, but disable Travel Link Quote Link to comment Share on other sites More sharing options...
omar302 Posted September 26, 2018 Report Share Posted September 26, 2018 On 9/26/2018 at 2:22 AM, redden18 said: There is a button now to do that next to glasses holder (at least on 2018MY Ti) Yes, there is a buton on 2015+ models to turn off interior lights when doors are open, but Dark mode also disables the exterior lights from coming on with the doors. You can also enable an option for it in the instrument cluster (named "Silent Mode") to enable/disable dark mode whenever you want. Good when washing/cleaning the car. 1 Quote Link to comment Share on other sites More sharing options...
redden18 Posted September 28, 2018 Report Share Posted September 28, 2018 On 9/26/2018 at 3:53 AM, omar302 said: You can also enable an option for it in the instrument cluster (named "Silent Mode") to enable/disable dark mode whenever you want. Good when washing/cleaning the car. Could you elaborate how? Quote Link to comment Share on other sites More sharing options...
omar302 Posted September 28, 2018 Report Share Posted September 28, 2018 I remember I followed mid for the dark car mode (police option) in the 2GFusion sheet. https://docs.google.com/spreadsheets/d/1yax6zfhZYj2joBczEeruqKh9X5Qhee3C0ngilqwTA7E/pubhtml?gid=0&single=true 1 Quote Link to comment Share on other sites More sharing options...
cv27 Posted September 30, 2018 Report Share Posted September 30, 2018 On 9/21/2018 at 9:26 PM, cv27 said: I tried this mod successfully on a 2015 Titanium, but it appears not to work on a 2016 Titanium. Can someone please confirm they were able to do this on a 2016? Sorry to bump, I really need confirmation on this one. Quote Link to comment Share on other sites More sharing options...
redden18 Posted October 14, 2018 Report Share Posted October 14, 2018 (edited) On 9/30/2018 at 2:14 PM, cv27 said: Sorry to bump, I really need confirmation on this one. see post #120. this mod does work on all vehicles with SYNC 2 and 3 no matter MY Edited October 14, 2018 by redden18 Quote Link to comment Share on other sites More sharing options...
