Downtown1978 Posted September 25, 2017 Report Share Posted September 25, 2017 I am trying to replace the air vents located on the middle console that blow air to the back seats. Where can I access the vent to remove it and replace it? Quote Link to comment Share on other sites More sharing options...
omar302 Posted September 25, 2017 Report Share Posted September 25, 2017 If they are the same as the MKX, the whole rear panel pulls out, then disconnect the wiring for the 12v power point to completely remove the panel. Then you'll find that the baby's are held in with screws. I did couple of years ago, so memory might not be that accurate. 1 Quote Link to comment Share on other sites More sharing options...
Downtown1978 Posted September 26, 2017 Author Report Share Posted September 26, 2017 The whole back part of the console pulls out? Just under the vents is what appears to be an access point, bout one inch by 5 inches. Does that cover need removed in order to pull the back part of the console off? Quote Link to comment Share on other sites More sharing options...
omar302 Posted September 27, 2017 Report Share Posted September 27, 2017 Check the parts diagram here, it'll give you a clear picture. 1 Quote Link to comment Share on other sites More sharing options...
Downtown1978 Posted October 2, 2017 Author Report Share Posted October 2, 2017 Got it, thx for the help Quote Link to comment Share on other sites More sharing options...
