active park assist uk
It does look like it's possible, but you need specialized software to reflash the PAM module with the active park assist code, then you need to use Forscan to hack the option data and you have to install the button to activate it and associated wiring harnesses which are probably way more than 150 quid.
If you're really interested, here is a writeup for the Fusion (Mondeo) that should be similar.
http://www.2gfusions.net/showthread.php?tid=6712&pid=118253#pid118253
