Gbczyk84 Posted November 10, 2017 Author Report Share Posted November 10, 2017 well, that's not good! have you replaced the pcv valve yet? I did not, when i did the spark plugs at 75K it was changed, valve cover around 85K so didnt find it necessary to do. I did swap a new one last night, the old one was pretty drenched with oil. Quote Link to comment Share on other sites More sharing options...
Gbczyk84 Posted November 10, 2017 Author Report Share Posted November 10, 2017 On my MKX, before the replacement cover, I saw oil on the intake tube up to the throttle body, though did not see it on the filter itself. I had the cover replaced at least a 18 months ago, and recently I checked & still no oil was present in the intake tube or throttle body. When you have the valve cover replaced, did you clean the whole intake tube? Maybe there was oil residue. Yes had that tube cleaned, also removed the throttle body at the time for a proper clean from both sides. Quote Link to comment Share on other sites More sharing options...
macbwt Posted November 11, 2017 Report Share Posted November 11, 2017 What is your current oil consumption? 1/2 to 3/4 quart over 200 hours of engine time 1 Quote Link to comment Share on other sites More sharing options...
manuelo2780 Posted January 25, 2018 Report Share Posted January 25, 2018 Hello guys. Thanks for share all this information. Currently I do have a 2012 explorer, which has the same problem, I've to clean every month, depending on how much I use it, I've had read the forum, but I still have doubts about if I've to buy the new design valve cover? It solves the problem? Thanks Quote Link to comment Share on other sites More sharing options...
Gbczyk84 Posted February 4, 2018 Author Report Share Posted February 4, 2018 To update, close to 100K miles now, since changing the PCV at last rant all is dry. No new issues with oil in the intake. 2 Quote Link to comment Share on other sites More sharing options...
