Jtricer Posted September 6, 2017 Report Share Posted September 6, 2017 I have a 2013 Ford Edge that has the power liftgate on it, I have been having trouble with liftgate arm not working properly sometimes it will open normally from the remote or the button on the dash, then maybe the next time you try it the liftgate may come up some then drop back down. If you hit the remote two times really quick it may or may not go up or down properly. Today it has started doing a thing where if the hatch doesn't go up properly then it will honk the horn. Yesterday I took the liftgate actuator off of another Ford Edge of the same year and it seemed to be okay I operated it about ten times or more and it worked fine. I put the original actuator back on and today it acts crazy again and the horn honking is a new thing it's doing Any ideas ? Thanks any help would appreciated Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 6, 2017 Report Share Posted September 6, 2017 The fact that the replacing the actuator fixed the problems indicates that your existing actuator is bad. Looks like their running <$300 on Ebay. 1 Quote Link to comment Share on other sites More sharing options...
evh Posted September 6, 2017 Report Share Posted September 6, 2017 I wonder if the gas struts are bad/weak? I don't disagree with the actuator thought of enigma and the testing you did but here is a thought. I wonder if the horn honks because it thinks something is in the way of the hatch opening (obviously there is nothing there). If the struts can't help it up a weak actuator may fail if the struts can't help it along. Just a thought. Not sure why you didn't leave the other actuator on, but if it's a cost thing, 2 new struts may be the solution. Just spit-balling some another idea.... Quote Link to comment Share on other sites More sharing options...
Jtricer Posted September 6, 2017 Author Report Share Posted September 6, 2017 The only reason I didn't leave the actuator on was it came off of my mother in laws car. After I put the original one back on my car it worked almost perfectly the rest of that day then yesterday it started acting up again. I don't want to throw a $200 part at the problem if I'm not absolutely certain that will fix it. Quote Link to comment Share on other sites More sharing options...
pedro2u Posted September 6, 2017 Report Share Posted September 6, 2017 why don't you swap the actuators between the 2 Edges's and wait to see which one has the problem? Sounds like a luxury to have a twin to trade toys with Quote Link to comment Share on other sites More sharing options...
IWRBB Posted September 6, 2017 Report Share Posted September 6, 2017 How about just comparing how each hatch opens by hand? If one has weak struts, it should be obvious when opened by hand. Quote Link to comment Share on other sites More sharing options...
Jtricer Posted September 6, 2017 Author Report Share Posted September 6, 2017 Thanks I did try the opening by hand method without the actuator arm attached and they both do the same thing as far as how fast they go up. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 6, 2017 Report Share Posted September 6, 2017 The only reason I didn't leave the actuator on was it came off of my mother in laws car. After I put the original one back on my car it worked almost perfectly the rest of that day then yesterday it started acting up again. I don't want to throw a $200 part at the problem if I'm not absolutely certain that will fix it. Oh, sorry, misunderstood. Thought the different actuator works perfectly and when you put the old one back on, didn't work again. Believe there is a rear hatch module that controls the it's operation. Perhaps the oem actuator is sending the wrong signals? (Never really looked at the service manual to see what controls the actuator). Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 6, 2017 Report Share Posted September 6, 2017 Was riding in a different forum where a service rep wrote about this problem "We have had a few come in like that. We replaced the lifting arm and the control module and all was fixed. Could have probably gotten away with just the module, but the Tech Hotline said to start with the lifting arm.". Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 6, 2017 Report Share Posted September 6, 2017 Similar problem on YouTube Quote Link to comment Share on other sites More sharing options...
