Mgavin1985 Posted August 31, 2017 Report Share Posted August 31, 2017 I am looking for advice I have 2013 edge trim is SE. I bought the factory sport wheels 22 inches. what can I do for a spare? can I use the spare wheel and just put a larger tire on it to match the height of the sport wheels on 265/40r22 tires or does the sport trim come with a different spare wheel? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 31, 2017 Report Share Posted August 31, 2017 I dont think a fullsize tire will fit in the spare area, but macbwt can comment further on that. He checked this out recently. Quote Link to comment Share on other sites More sharing options...
akirby Posted August 31, 2017 Report Share Posted August 31, 2017 I think the question was could he swap out the temporary spare tire so it matches the height of the new tires. There is a 1.3 inch height difference between the factory sport tires and the SE tires. I don't know if they supply a different spare from the factory or not - that's only a 4% difference. Perhaps someone with the factory 22s can provide their spare tire specs for comparison. I couldn't find them on fordparts.com. You could go with a slightly shorter sidewall on the 22" tires to keep them the same diameter if you're buying new tires. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 31, 2017 Report Share Posted August 31, 2017 gotta be able to store it in the Edge, no good if you can't. that's what I was getting at Quote Link to comment Share on other sites More sharing options...
akirby Posted August 31, 2017 Report Share Posted August 31, 2017 gotta be able to store it in the Edge, no good if you can't. that's what I was getting at I know but it's a temporary spare not a full sized spare which will fit either way. Quote Link to comment Share on other sites More sharing options...
IWRBB Posted August 31, 2017 Report Share Posted August 31, 2017 Is your Edge AWD? If not, differing tire heights don't matter. Quote Link to comment Share on other sites More sharing options...
macbwt Posted September 2, 2017 Report Share Posted September 2, 2017 It does not matter the spare is only designed for about 50 miles of use. If you have a flat the tire is only supposed to be operated at 50 mph. Enough to get you to the tire shop. The AWD system will adapt short term to the difference. Main theory being you quickly get the tire replaced/repaired. 1 Quote Link to comment Share on other sites More sharing options...
JETZ Posted September 4, 2017 Report Share Posted September 4, 2017 With a stock 40 series sidewall, how much shorter are you thinking to bring it to the same height as the spare (which I believe is a 18" wheel). Your logic won't hold water. The 'space saver' spare is just that. Even a small 245/60/18 tire will not fit in the spare cavity. 'You could go with a slightly shorter sidewall on the 22" tires to keep them the same diameter if you're buying new tires'. I think the question was could he swap out the temporary spare tire so it matches the height of the new tires. There is a 1.3 inch height difference between the factory sport tires and the SE tires. I don't know if they supply a different spare from the factory or not - that's only a 4% difference. Perhaps someone with the factory 22s can provide their spare tire specs for comparison. I couldn't find them on fordparts.com. You could go with a slightly shorter sidewall on the 22" tires to keep them the same diameter if you're buying new tires. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 4, 2017 Report Share Posted September 4, 2017 My spare on my MKX with 20" wheels and AWD is a 165x80x17. I've used it twice with no problems. (Cept it rides hard and noisy). 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted September 4, 2017 Report Share Posted September 4, 2017 With a stock 40 series sidewall, how much shorter are you thinking to bring it to the same height as the spare (which I believe is a 18" wheel). Your logic won't hold water.The 'space saver' spare is just that. Even a small 245/60/18 tire will not fit in the spare cavity. 'You could go with a slightly shorter sidewall on the 22" tires to keep them the same diameter if you're buying new tires'. I was referring to whether the existing temp spare would work ok with the factory 22"s (assuming the same size factory tires). I think it's ok - I doubt they use a different temp spare for the factory 22s even on AWD models since you're only supposed to drive for max 50 miles. The issue on replacing the temporary spare with a regular tire is not the diameter but the width. A regular tire is too tall laying on its side. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 5, 2017 Report Share Posted September 5, 2017 The issue on replacing the temporary spare with a regular tire is not the diameter but the width. A regular tire is too tall laying on its side.Height as well. I had a flat and tried to put the regular tire in the well for trandport. Not even close. Way too big. As I stated, mine is a 17". From the looks of it, don't believe an 18" will fit. Do you have an 18" in yours? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 5, 2017 Report Share Posted September 5, 2017 Just checked ebay. A 17" is the std. high for all Edge/MKX for 2007-2013. 18" would be too big for the well. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 5, 2017 Report Share Posted September 5, 2017 Just checked ebay. A 17" is the std. high for all Edge/MKX for 2007-2013. 18" would be too big for the well. Used spare for a 2013 Edge runs around $100 shipped. 1 Quote Link to comment Share on other sites More sharing options...
Mgavin1985 Posted September 7, 2017 Author Report Share Posted September 7, 2017 Thanks for replies that is good news I'll just use SE spare in case of flat. I replaced tires on sport rims for the first holy Christ are they expensive I went with new general tires g-max as 05. I wanted Contential DWS but too expensive. Contential owns general so these are suppose to be poor mans DWS. Looks like tread should be decent for winter weather Quote Link to comment Share on other sites More sharing options...
Mgavin1985 Posted September 7, 2017 Author Report Share Posted September 7, 2017 And brake booster I drove home from tire shop and then heard the hissing sounds of the brake boaster issue and had it towed to dealer only drove abot 20 miles on tire I posted in other section about how that situation was when it happened. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 7, 2017 Report Share Posted September 7, 2017 Couple of things about 22's. They run hard and wear out fast. (Not my words, Ford's. In the Owners Manual.) They do not warrant 22" tires are the fail easily and wear out quickly. At dealers for oil change, service agent came in waiting area to bs, told me just just replaced 2nd tire for Edge that just left. First tire hit a pothole, second one picked a up a screw. Guy was complaining that that tires were junk and getting expensive. (Car was only two months old at that point and he had already bought two new tires.) Hopefully you will not run into such bad kick like he did, but I would recommend you carry a spare; as the odds favor it. 1 Quote Link to comment Share on other sites More sharing options...
Mgavin1985 Posted September 8, 2017 Author Report Share Posted September 8, 2017 Thanks I'll be looking for a buy 4 get 1 free Quote Link to comment Share on other sites More sharing options...
Mgavin1985 Posted September 8, 2017 Author Report Share Posted September 8, 2017 Got edge back was boster dealer covered no problem Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 8, 2017 Report Share Posted September 8, 2017 Got edge back was boster dealer covered no problemWelcome newest member of the Ford Booster Club. You don't by chance have AWD do you? (Big grin). Quote Link to comment Share on other sites More sharing options...
Mgavin1985 Posted September 8, 2017 Author Report Share Posted September 8, 2017 I actually have a FWD SE is their any other warrenties or problems edges have? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 8, 2017 Report Share Posted September 8, 2017 (edited) 3.5L engine noted for water pump failures (allows coolant to leak inside the engine, diluting the oil and killing the engine. One good way to prevent is to change coolant on schedule. Plastic guides wearing on timing chains. (Again do all scheduled maintenance is best defense). 2.xL direct inject turbo engines noted for carbon buildup on back side of intake valves. Several have installed Catch Cans with varying results. Fuel tanks corroding and leaking gas. (Recalls issued). Air bags needing replacing. (Recall). Brake boosters failing. (Ford replacing on several different years). (What did I forget?) All-in-all, a very reliable car. Edited September 9, 2017 by enigma-2 Quote Link to comment Share on other sites More sharing options...
