Touch screen wont recognize touch.
2104 Edge touch screen comes on shows all information but will not recognize touch. Back up camera works, Voice command works and screen will change using voice command. I have tried removing fuse 29 to reset, system restarted but still does not recognize touch.
Any ideas to fix?
Probably need to do a master rest (cutting power doesn't do this). If you still do it, try this:
1. Access your Settings Menu by clicking the cogs located next to the Home Button
2. Select Settings from the list on the right side of the screen
3. Select System at the top of the list
Scroll down until you see Master Reset, then press it. (if you can).
If not, need to take it to the dealer. They can do a master reset or diagnose the problem (replace the display).
