cmhhawaii Posted August 24, 2017 Report Share Posted August 24, 2017 I have been having an issue with my 2011 Edge running rough at idle. The edge has 77,000 miles. Here's the story: I was having trouble with a cylinder misfire under normal driving. The code read "misfire cylinder 5". I took it into the dealer. They told me I had a bad coil on cylinder 2. They would replace it for $800, but recommended replacing all of them for $2,500. I passed on their offer and performed the repair myself. I found a cracked insulator on the spark plug at cylinder 5. I replaced all of the coils and spark plugs anyways - for good measure. The misfiring cylinder was solved. Since I was under the hood and had the intake off, I took the opportunity to swap out my air filter and clean the mass airflow sensor. I bought a nice K&N air filter and installed it and cleaned the mass airflow sensor with CRC mass airflow sensor cleaner. After driving around for a while, I got a check engine light with fuel/air codes. I figured this was due to the increased airflow from the new high-performance filter. I swapped it out for a normal paper filter. The engine codes went away. Well, it seems these things come in threes: The following few weeks, the engine started running very rough at idle. I suspected a vacuum leak somewhere. I removed the intake manifold, to see if I had damaged a gasket , or forgot to connect a line. Everything looked good. Then, I checked the Emissions Vapor Canister Purge Valve and it does not appear to be malfunctioning. All the lines on the intake side appear to be seated correctly. Does anyone have any suggestions on where to look next? -Thank you in advance Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 24, 2017 Report Share Posted August 24, 2017 Codes? Brakes working fine? Checked the OCM coil drivers? Not known to be an issue on gen 1.5, but ... Possibly a throttle body issue? I would take the TPS off and check it fir wear and carbon tracking. If found, replace the throttle body. Cheap fix right now. Clean the MAF sensor again, but you may need to replace it. I had to on my Edge, as no amount of cleaning would help with throttle response issues. With either of these fixes, you should perform a KAM reset and let the PCM learn the new components. Quote Link to comment Share on other sites More sharing options...
cmhhawaii Posted August 25, 2017 Author Report Share Posted August 25, 2017 No codes with just the rough idle. TPS is a fair suspect, but the issue only occurs at idle... TPS would give me issues throughout the throttle range (right?). I reset the PCM with my last round of fixes - no change. I really think it has to be the Mass Airflow Sensor. Is there a good way to test it without replacement? Quote Link to comment Share on other sites More sharing options...
cmhhawaii Posted August 25, 2017 Author Report Share Posted August 25, 2017 And no brake issues Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 25, 2017 Report Share Posted August 25, 2017 If it is a miss fire then check for a misfire. Did you check the Purge valve solenoid for vacuum? What was the vacuum reading? Anything below 7 and you have a failed/failing purge valve. Spark and fuel are your concerns at this point. Are the injectors all working? What are your O2 sensors reading? 1 Quote Link to comment Share on other sites More sharing options...
cmhhawaii Posted August 29, 2017 Author Report Share Posted August 29, 2017 I replaced the Mass Airflow Sensor, thinking that it could have been my vigorous cleaning that caused a misread at low air volume. No change. I think I'm back to searching for a vacuum leak Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 29, 2017 Report Share Posted August 29, 2017 Is the brake booster a possibility in this case? Quote Link to comment Share on other sites More sharing options...
fishx65 Posted August 29, 2017 Report Share Posted August 29, 2017 (edited) Check to see if your 2011 qualifies for the free throttle body replacement. My 2011 got a new one a few months ago. http://www.fordedgeforum.com/topic/21405-throttle-body-recall/ Edited August 29, 2017 by fishx65 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 30, 2017 Report Share Posted August 30, 2017 What is the fuel pressure. Have the Fuel Pressure checked. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 30, 2017 Report Share Posted August 30, 2017 What is the fuel pressure. Have the Fuel Pressure checked.He said he had no codes. Low pressure would have set P0087 (think that's the one). My guess is he split a vacuum hose when he removed/reinstalled the intake. Still, that should also set a code. 2 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 30, 2017 Report Share Posted August 30, 2017 Just curious, did you use OEM plugs and coils? 2 Quote Link to comment Share on other sites More sharing options...
akirby Posted August 30, 2017 Report Share Posted August 30, 2017 What is the fuel pressure. It's how much force the pump is providing to the injectors. But that's not important right now...... Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 31, 2017 Report Share Posted August 31, 2017 It's how much force the pump is providing to the injectors. But that's not important right now...... LOL I know what fuel pressure is. But maybe it is low or fluctuating and not quite enough to cause a CEL. Stranger things have happened. Be nice to see if there is a misfire count. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted August 31, 2017 Report Share Posted August 31, 2017 LOL I know what fuel pressure is. But maybe it is low or fluctuating and not quite enough to cause a CEL. Stranger things have happened. Be nice to see if there is a misfire count. 2 Quote Link to comment Share on other sites More sharing options...
cmhhawaii Posted November 12, 2017 Author Report Share Posted November 12, 2017 Just curious, did you use OEM plugs and coils? No, I didn't use OEM coils. Too expensive Quote Link to comment Share on other sites More sharing options...
painmedsplease Posted May 25, 2024 Report Share Posted May 25, 2024 I was wondering what brakes have to do with this issue? I am experiencing rough idle right now after fuel injector replacement. This was a non-issue before but someone opened the brake fluid reservoir and now we have really hard brakes (will have to bleed). But it now has a rough idle and dies whereas before we were experiencing a mis-fire at highway speeds after all OEM coil/plug replacement (three years ago) and ECM being fixed. 1 Quote Link to comment Share on other sites More sharing options...
gonesail Posted May 26, 2024 Report Share Posted May 26, 2024 i did the plugs on mine and jostled one of the electrical connectors .. i think a fuel injector. it idled rough but there was a code. i was able to reach in and press the connector back in place. but without the code you are just guessing. Quote Link to comment Share on other sites More sharing options...
garycrist Posted May 26, 2024 Report Share Posted May 26, 2024 If a vacuum leak develops between the manifold and brake booster or a rupture of the Brake Booster Diaphragm, will cause a rough idle. Bleeding the brakes will have not solve a "Hard Pedal". Quote Link to comment Share on other sites More sharing options...
