enigma-2 Posted August 28, 2017 Report Share Posted August 28, 2017 Sadly my extended warranty comes to an end next month. After this will will only cover the cup holders (I think). The best insurance is to do all of the preventive maintenance, and other stuff not required (such as changing the PTU, axle, brake and pwr steering fluid$). I also authorize most repairs the service department recommends. Fix it now before it causes others parts to weaken and fail. (I.E. a worn Tie rod end thats getting worn will put extra stress on the rest of the suspension and drive leakage). 1 Quote Link to comment Share on other sites More sharing options...
walsh_dw Posted August 23, 2018 Report Share Posted August 23, 2018 I had some serious reservations about the turbo but ultimately decided to buy it... Now here I am 4.5 years later in the same boat that I'm realizing a lot of people are in... I was just curious if anyone has replaced their turbo with a non-OEM product and had better results, or if it is just safer to do a stock replacement and hope to get as many miles out of it as you can?? I'm sitting at 110k miles and was told today that I will surely need to replace the turbo soon. Quote Link to comment Share on other sites More sharing options...
akirby Posted August 23, 2018 Report Share Posted August 23, 2018 I would not trust aftermarket. What are your symptoms? 1 Quote Link to comment Share on other sites More sharing options...
tamugrad2013 Posted August 24, 2018 Report Share Posted August 24, 2018 I am actually interested in the symptoms as well. When mine failed it was in for two things (AC Compressor conked out and the continual transmission woes). After the service department got the compressor fixed they were test driving it and still diagnosing the transmission they said it threw codes and the check engine light came on along with low power. I still wonder how it failed all of a sudden with no symptoms apparent to me. Of course as it was under extended warranty and I was already paying the deductible for the compressor and the transmission fix so might as well throw in a turbo. 1 Quote Link to comment Share on other sites More sharing options...
JTW Posted November 25, 2021 Report Share Posted November 25, 2021 What's the most common failure with the Turbo? Is it seals or the waste gate linkage wearing out? I would think the linkage would have been updated by now. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 26, 2021 Report Share Posted November 26, 2021 to date, the most common failure has been the wastegate actuator/linkage. occasionally, the c clip will pop off, but not as common. common does not equal frequent. no need to update design if it does not even merit a tsb. Quote Link to comment Share on other sites More sharing options...
JoeyDirt Posted April 22, 2024 Report Share Posted April 22, 2024 On 8/24/2017 at 5:45 AM, TheWizard said: I can appreciate that you are unhappy about the engine problem but you can't expect any company to extend their warranty by more than 50% simply because you don't think you should have to pay for the replacement. It's called a "limited warranty" because it's limited both in how long it applies and what is covered. Sure, if you had the same failure at 51,000 miles then there would be a case for having it covered as a good will item (although that would still be at Ford's discretion). But at 80,000 miles you are not even close to having just run out of warranty. If companies were to cover repairs that far out of warranty then they might as well not have any limits to their coverage and significantly raise the price of every vehicle to cover their anticipated repair costs forever (not to mention the loss of most future sales because buyers have no incentive to buy new if they can get their old one fixed for free). Basically, what you are asking for is unreasonable. You absolutely can when they retitle this as an update vs a recall. Why else would the "update" require a new cat to go with the new design? Please.... Quote Link to comment Share on other sites More sharing options...
