cindy75 Posted August 23, 2017 Report Share Posted August 23, 2017 I know how to add, and there are videos, etc. But how do you remove??? I've deleted my phone book, redownloaded. Of course Quick Dial doesn't live in my phone's phone book. Help! Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 23, 2017 Report Share Posted August 23, 2017 Delete your phone from the car, it should delete everything related to your phone. Then re-add it. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 28, 2017 Report Share Posted August 28, 2017 You can't (directly). You can select a phone number and assign it to an existing quick dial location which will overwrite the existing number, or you can do "master reset" which will delete your phonebook and all the quick dial settings. To set a different number for quick dial, select phonebook, select your number and select which quick dial location to set it for. If it currently has a number assigned, select "replace". Quote Link to comment Share on other sites More sharing options...
