Airbag recall
Hi,
One year ago (July 2016) I received a letter from Ford about the airbag recall for my 2007 Edge.
Since then I haven'd heard a beep from them and the guys at the Ford dealership I purchased the car from only shrug their shoulders.
Is there any way to find out what in the world is going on here?
Thanks,
Ed
Is Takata the only airbag manufacturer in the world?
This issue has been going on so long, there was plenty of time to find several replacement manufacturers if Ford would care about the life of their customers.
Heck, they could've started their own manufacturing in one of their plants.
Ā
The Takata airbag recall affects over 100 million airbag inflators worldwide (some vehicles have multiple airbags affected by the recall) affecting 19 different car manufacturers. Takata filed for bankruptcy a couple months ago in Japan and USA because of all the recalls and associated lawsuits. Takata's largest competitor, Key Safefy Systems, bought Takata's assets is continuing to manufacture inflators for the recalls. Apparently there are other inflator manufacturers getting involved now as well to help speed things up, but it's going to take a while to get all those airbags replaced.
Ā
If you Google "Takata airbag recall" you should find a lot more detail including areas that are being prioritized for replacement airbag inflators (the problem is worse in high humidity / high temperature conditions). This isn't just a Ford problem.
  • 4 months later...
I just got a new notice about the airbag recall.
Ford is anticipating replacements available in the spring. My car is originally from Louisiana and then Arizona. It is now in
Connecticut. I was told that Louisiana puts in in first place for the recall.
I think that the lawyers told them to write this letter because they state that until the air bag is replaced you shouldn't have passengers in the front seat. and that this would deactivate the airbag.
I think they are full of *%$#. They just want to tell you not to use the front seat and if you do it's your fault. If I ever see the replacement I'll be 100. :swear:
Edited by PaulSchott
Just think, what it they told you that no one should sit in tbe drivers seat?
