Enabling Global Close for 2011-2015 MKX
This ABD edit enabled a menu in the instrument cluster to enable "Global Close" and it works, it will close the front windows, but not the sunroof/shade, by pressing & holding the lock button on the fob.
Using Forscan I changed the following:
720-01-02 xxxx xXxx xxxx from "A" to "B". If you have previously disabled the fog light indicator, you'll then be changing it from "2" to "3".
Credits to "sheltonfilms" from the Ford Explorer forums.
Edited by omar302
  • Like 3
Your welcome as well since I provided it to him for testing on his explorer. lol
Edited by jmr061
  • Like 3
Jason, if we have to thank you for each credit you deserve, then I'd have to add it to my signature. Your contributions are countless. Now only if we can get more mods from you :).
Edited by omar302
  • 2 years later...
I have a 2011 Edge Limited. The windows have the safety feature where they will reverse direction if hitting an obstacle but I can't get my global open/close to work.  I have the IPC bits set for Global open and Closed to "enable" but it does not show up in my left hand dash panel under settings. I've seen several global open changes, but none either work or match what's in there.  Can someone with an MKX or Edge tell me if they have a DCM or PCM (driver and passenger Door Module)) that needs altering? Any help is appreciated.
