Calgary0123 Posted August 18, 2017 Report Share Posted August 18, 2017 Ok I posted a few days ago but didn't get a solution so here goes again , drivers window control does all windows but not drivers window , changed out PW control switch but exactly the same thing , all windows but not drivers , all windows operate separately ok. I also have no moon roof power and no interior panel lights , vanity mirror light works, and back hatch , trunk light works ,,,, changed our about 5 fuses , no relays ........ ant help or suggestions is appreciated, thanks Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 18, 2017 Report Share Posted August 18, 2017 (edited) Was there any noise operating the driver's window prior to this complete failure? If so, it is possibly the window motor (about 55$ Dorman brand (742-195) from RockAuto). Or if the switch worked intermittently, then you may need to replace the switch bezel (includes window switches and window lock toggle) - about 25$ or less (eBay - 7T4Z14525AC for black). The oldfashioned method would be to check the switches for continuity, as well as the window motor (for which you have to remove the door panel, not too bad). Edited August 18, 2017 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
Calgary0123 Posted August 18, 2017 Author Report Share Posted August 18, 2017 Going to replace motor on Monday, any idea on power to sunroof and panel lights? Thanks Quote Link to comment Share on other sites More sharing options...
Calgary0123 Posted August 19, 2017 Author Report Share Posted August 19, 2017 Are there an relay switches that control power to the the panel lights and moonroof power Quote Link to comment Share on other sites More sharing options...
Calgary0123 Posted August 19, 2017 Author Report Share Posted August 19, 2017 Replaced drivers window switch , no fix, unplugged battery overnight so we'll see if that does anything , Still no power to dome lights and moonroof,,, any suggestions are appreciated, cheers Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 19, 2017 Report Share Posted August 19, 2017 If there is full power to the connector that plugs into the window regulator then Bob's your uncle. Regulator motor is bad. 2 Quote Link to comment Share on other sites More sharing options...
Calgary0123 Posted August 21, 2017 Author Report Share Posted August 21, 2017 Still no luck , change switch , fuses , motor and still main switch will control 3 windows but not drivers window Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 21, 2017 Report Share Posted August 21, 2017 I dont think the BCM controls any of these functions does it? Other than that it seems like an electrical issue? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 28, 2017 Report Share Posted August 28, 2017 With all of the unrelated faults that are occurring, there appears to be only one component that's common to all. It's the Smart Junction Box. Before taking it to a dealer however, how old is you battery? Batteries that still test good on a regular tester will still have internal problems and cause problems with circuits. (Unlikely in your case, but still a distant possibility). Those two items would be the first thing I would suspect as to the root cause. BTW, the drivers window is powered from fuse #4 in the SJB (cabin fuse panel). It's a 30 amp fuse. Did you check it? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 18, 2017 Report Share Posted September 18, 2017 https://www.google.com/url?q=http://www.fordedgeforum.com/topic/23134-driver-side-power-window-switch-2013-ford-edge-limited/ Looking at the wiring harness/connector may be a good place to start. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 18, 2017 Report Share Posted September 18, 2017 (edited) Below is a video where FordTechMakuloco was tracing down a complaint concerning drivers door lock failure and window not working. He finally tracked it down about 2/3 the way through and may be coom on to your problem. (At least easy to check). Edited September 18, 2017 by enigma-2 Quote Link to comment Share on other sites More sharing options...
