Newless Posted August 17, 2017 Report Share Posted August 17, 2017 Hey folks, 2009 fwd, needs a front wheel bearing. Just starting to make a noise. Not toast yet. I did a search and found conflicting info, so I'll lay it out. Got a quote today for $332.32 to replace. This is a pressed in wheel bearing, others say different. Pressed in. I've done some work to my fords, from suspension, brakes, evap, cooling. I do have a ton of tools, and have done a handful of wheel hub assemblies on Gm's. I have not done a pressed in wheel bearing. I live in Canada with heavy salt and rust, making even removing tires a sledgehammer job when on for a long time with no anit-seize. Has anyone done this at home, with heavy rust and not kicked their dog or pulled their hair out? I was looking at buying a ATD front wheel drive bearing tool from amazon and giving it a try. Or swallow my pride and pay the dough and be done with it. Any experience out there on this job? Thx! Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 18, 2017 Report Share Posted August 18, 2017 I have not made a video on this yet. I am still waiting for my front wheel bearings to fail. I am currently at 205,000 miles on my 2011. I am sure one day one will start to fail, but no idea when. I just replaced the rear hub and they were a real PITA and required high heat, a hand sledge and a sliding sledge at the same time to remove them. They were both rust welding into the suspension. I am planning on replacing not only the bearing, but the front hub also on the fronts when the time comes just because I do not want to deal with the rust. 1 Quote Link to comment Share on other sites More sharing options...
IWRBB Posted August 18, 2017 Report Share Posted August 18, 2017 It is pressed in based upon looking at pics of the bearing on Rockauto. 2 Quote Link to comment Share on other sites More sharing options...
