Hello,
I recently purchased a 2014 Ford Edge, SEL with 17,000 miles on it. I recently started to hear an intermittent squeak/chirping noise from the front end while driving slowly (10-20mph). It seems to come on a bit more when I accelerate then disappears above 20 mph.
Seems to do it after vehicle has warmed up. Car does not pull to either side, and sound seems to go away went brakes are applied, but maybe only because it is slowing down. Brakes appear good
Could the CV joint, wheel bearings, etc. be already out with so few miles? Any zerk or lube joints I could hit in this area?
Thank you for your time!
UPDATE: I can now reproduce the chirping noise. It occurs when I let off the gas and am coasting at lower speeds.
It is a chirping and spinning noise. It stops when I accelerate again. Any thoughts?
I did have a Tacoma that did this and some grease in the u joint fixed it. Being new to the Ford Edge, could this be the same or similar area.
Any experience or ideas? Thanks!
Congrats on the new ride. Very low mileage for a 2014. Either all local driving ir sat for long periods of time or both. Not good on brake pads as they can wear out from stopngo or actually bond to the rotors while immobile. As stated, check the brake pads, hopefully all that is needed is for the rotors to be thoroughly cleaned.
Update: I wanted to follow up in case this helps anyone else. I received a call from the service department today stating they are confident they found the issue: a loose axle nut. After a test drive they said there was no more noise. I will get it tomorrow and see. Thank you again for all your feedback.
