Liptoss Posted August 7, 2017 Report Share Posted August 7, 2017 I've purchased the plugs, manifold gasket, pcv and I'm ready to go. I've changed many spark plugs on all sorts of vehicles, but I'm rather perplexed at one thought. I understand it, but wonder if it's a good idea. In gathering the information that I need to "get the job done" I came across a Youtube video. Viewing it, the mechanic states that "Ford wants us to warm the engine up for a couple of minutes to aid in the release of the threads form the heads". The Duratec engines can have issue with spark plugs stripping the head threads. I've more or less always changed spark plugs on engines that were cool. I'm guessing that Ford figures the expansion rate of aluminum and the spark plugs difference will aid in the release of the spark plug threads to the heads. For those having performed changing your spark plugs on your Edge, or other Duratec 3.5 or 3.7 vehicle, what have you done? Cold or Warm? Have you noticed a difference? Am I just being "paranoid'? Thanks Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 7, 2017 Report Share Posted August 7, 2017 You probably don't have enough age on the plugs to make them resistant, but it is possible. My Edge was 9 years old before it got new plugs, and the ones in the back were somewhat more difficult than the ones in the front to remove. And yes, I hear the same thing about warming up the engine first esp when working with aluminum heads, from trusted sources. Quote Link to comment Share on other sites More sharing options...
Liptoss Posted August 7, 2017 Author Report Share Posted August 7, 2017 OK Thanks. I recall that I had a "moment" a few years back when I changed my previous Focus plugs. I forget which cylinder plug seemed to "stick", but I tightened it a bit, then loosed it, rocked it back and forth a bit. It came out in the end. I did the change on a completely cold engine. I'm wondering how common this issue is with the Edge Duratec. I've read online about older F-150's and spark plug removal nightmares. I don't recall putting any anti seize on the threads for the Focus. Wonder what I should do with the Edge? Quote Link to comment Share on other sites More sharing options...
fishx65 Posted August 8, 2017 Report Share Posted August 8, 2017 I just did the plugs in my 2011 with 90,000 miles on her. Changed them cold and didn't have any problems. I used a little anti-seize when installing the new plugs. A little tip for ya: just cut the tape to remove the wire harness running across the front of the intake and re-tape it when you're done. It's better and easier then trying to remove the plastic harness brackets. 3 Quote Link to comment Share on other sites More sharing options...
Liptoss Posted August 8, 2017 Author Report Share Posted August 8, 2017 Thanks for the advice on the tape. I was thinking the same. I wrench quite a bit on Japanese motorcycles and am totally familiar with successful extracting of grommeted plugs from holes. Going to begin the plugs this morning, and end with the serpentine belt replacement. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 8, 2017 Report Share Posted August 8, 2017 I would plan on doing the power steering belt at the same time. I think macbwt has a video for his 2008 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 9, 2017 Report Share Posted August 9, 2017 Water pump, timing chain guides? Quote Link to comment Share on other sites More sharing options...
Liptoss Posted August 10, 2017 Author Report Share Posted August 10, 2017 Plugs were completed 2 days ago. Really easy overall. Had approximately 145,000 kms Used new Ford gasket and PCV. Things I found the most troublesome were removing the COPs. Don't know if it's a suction thing or what, but I put a dab-el-do-ya in each of dielectric. Another was the initial break-free of the plugs. Creeeeeeeek loosen. Then tighten slightly back, then loosen again. Back an forth if I felt needed more. Cleaned the bore with air before full extraction of plug. Blew plug threads of debris after plug was out. Puff of grey brown sediment. All else was pretty simple. Save yourself a few bucks at the stealership. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted August 10, 2017 Report Share Posted August 10, 2017 Plugs were completed 2 days ago. Really easy overall. Had approximately 145,000 kms Used new Ford gasket and PCV. Things I found the most troublesome were removing the COPs. Don't know if it's a suction thing or what, but I put a dab-el-do-ya in each of dielectric. Another was the initial break-free of the plugs. Creeeeeeeek loosen. Then tighten slightly back, then loosen again. Back an forth if I felt needed more. Cleaned the bore with air before full extraction of plug. Blew plug threads of debris after plug was out. Puff of grey brown sediment. All else was pretty simple. Save yourself a few bucks at the stealership. Did you warm up the engine first? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 10, 2017 Report Share Posted August 10, 2017 Things I found the most troublesome were removing the COPs. Don't know if it's a suction thing or what, but I put a dab-el-do-ya in each of dielectric. You used hair cream on the coil sockets? Did you use Rogaine on the top of the spark plugs? 2 Quote Link to comment Share on other sites More sharing options...
Liptoss Posted August 10, 2017 Author Report Share Posted August 10, 2017 No I didn't perform this on a warm engine. Decided that I'd go back to tried and true what I learned over my years. I had the threads once fudge up on me with a lawnmower that had the plug sit in it for mega eons. It pulled the threads out with the plug partially. AGH! Not a great feeling when it happens to you once. I was much younger then, and know better now. It's a lot about feeling as you first begin the turn. Yeah, I used the grecian-formula to change the plugs from white look running lean. 1 Quote Link to comment Share on other sites More sharing options...
freebird Posted August 11, 2017 Report Share Posted August 11, 2017 I just changed mine a few days ago on a warm engine. 2012 has 71,000 miles on it and gap was out of spec. 1 Quote Link to comment Share on other sites More sharing options...
PaulSchott Posted August 11, 2017 Report Share Posted August 11, 2017 Brill Cream, a little dab-el-do-ya use more only if you dare, Brill Cream,a little dab-el-do-ya, They'll love to run their fingers through your hair. Not only are we dating ourselves, we are carbon dating ourselves. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 11, 2017 Report Share Posted August 11, 2017 (edited) groan (remember the "greasy kids stuff" ads)? Edited August 11, 2017 by enigma-2 1 Quote Link to comment Share on other sites More sharing options...
Liptoss Posted August 12, 2017 Author Report Share Posted August 12, 2017 DEP! I think it was called. And that dates me. My plugs were over the max gap limit after 145,000kms. I used Ford plugs. Anyone ever indexed their plugs? 1 Quote Link to comment Share on other sites More sharing options...
chefduane Posted August 12, 2017 Report Share Posted August 12, 2017 Dippity-Do. Quote Link to comment Share on other sites More sharing options...
PaulSchott Posted August 14, 2017 Report Share Posted August 14, 2017 I went to a costume party as a greaser. I used Vaseline in my hair. 3 shampoos later I was still sliding out of bed. Quote Link to comment Share on other sites More sharing options...
chefduane Posted August 14, 2017 Report Share Posted August 14, 2017 ...not sure if I'm completely comfortable reading a post with the words 'vaseline', 'sliding', and 'bed' used. 3 Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 15, 2017 Report Share Posted August 15, 2017 Duratec spark plug change, pcv and New Intake Gasket, TB gasket and cleaning of intake manifold. It only takes 51 minutes. 2 Quote Link to comment Share on other sites More sharing options...
