Oil Cooler Bypass Valve Removal
kaprellj
Can anyone tell me if, or what sort of special tool is available to remove the tubing connections from the oil cooler bypass valve on a 2007 ford edge? There is practically no room to work with here. A 19mm wrench fits but is very difficult to use given the tight area.
