Dehcure82 Posted August 5, 2017 Report Share Posted August 5, 2017 Ptu oil change Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 6, 2017 Report Share Posted August 6, 2017 Well, you a long straw and suck like crazy.....https://youtu.be/5PhLGyCOcbA 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 6, 2017 Report Share Posted August 6, 2017 If you have a Sport, you have a fill AND a drain plug, makes it much easier. Otherwise, drain & fill from the fill plug area just like 2007 onwards. Probably easier with Edge on jackstands/lift with right wheel & fender liner off. Quote Link to comment Share on other sites More sharing options...
Dehcure82 Posted August 6, 2017 Author Report Share Posted August 6, 2017 Thanks so much. Yes I have the sport, do you by chance know where the fill and drain is located? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 6, 2017 Report Share Posted August 6, 2017 (edited) HTH Edited August 6, 2017 by WWWPerfA_ZN0W 6 Quote Link to comment Share on other sites More sharing options...
Dehcure82 Posted August 6, 2017 Author Report Share Posted August 6, 2017 Awesome! Thanks again 1 Quote Link to comment Share on other sites More sharing options...
Dehcure82 Posted August 7, 2017 Author Report Share Posted August 7, 2017 Last question how much oil to refill with after draining? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 7, 2017 Report Share Posted August 7, 2017 If you can drain it all, theoretically it will take 18 ounces of new fluid for the fillup, per the user manual. I would keep a quart of new fluid on hand at minimum. Motorcraft is fine if you are going to flush at regular intervals, but there are better choices out there, including Redline, Amsoil, etc. Otherwise you can get Valvoline and Mobil1 for pretty good prices too. Quote Link to comment Share on other sites More sharing options...
Dehcure82 Posted August 8, 2017 Author Report Share Posted August 8, 2017 Ok that would be my up coming weekend project. Thanks 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 9, 2017 Report Share Posted August 9, 2017 Good luck, and take pics! Quote Link to comment Share on other sites More sharing options...
