Jlacyphotos Posted August 5, 2017 Report Share Posted August 5, 2017 Hi all, just signed up for my membership, I have a 2013 Edge SEL (wife), 2013 Fusion (daughter), 2013 F-150 FX4 (son) and a 1996 Bronco (mine) to round out the fleet. Having an issue with hot weather no starts, I just posted my first thread. Great info here!!! Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 5, 2017 Report Share Posted August 5, 2017 Welcome to the community, nice fleet if not the battery (check cca's), very likely the starter. Quote Link to comment Share on other sites More sharing options...
Jlacyphotos Posted August 5, 2017 Author Report Share Posted August 5, 2017 Battery and cables are good, changing shifter position doesn't change condition. If I pull the starter relay and jump across it with the key in "run", the motor cranks and runs. That tells me it's between the switch on the cylinder and the PCM (or whatever module the ignition switch talks to) or the PCM and relay. Replaced the relay, no change in condition. It's very intermittent and impossible to reliably duplicate. It almost never happens on cooler days. If the cabin temp is high, like sitting in the sun with the windows up, that's when it happens. If you sit for a bit with the windows down or the doors open it will usually start. It's very frustrating...what's also frustrating is that I changed the switch a bit ago (actually easier than expected) and it would not crank at all with the new switch. I put the old one back in and it cranks...tried moving the wiring around at the connector, visually checked the terminals to be sure none had backed out of the socket and got no change. I went back and forth between switches just to be sure... I'm wondering if there's a programming issue with replacing the switch or something.... If it was easier to duplicate or happened more often, I'd just pay the deductible and let the dealer figure it out. The switch was cheaper than my 7/100 deductible so I figured I'd take the chance... Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 5, 2017 Report Share Posted August 5, 2017 Do you have Intelligent Access keys? Any codes set in the PCM/BCM/...? The manual lists the following suspects for no-crank conditions: Battery Battery cables Fuses Ignition switch Starter motor Starter relay Run/start relay PCM Transmission Range (TR) Passive Anti-Theft System (PATS) Body Control Module (BCM) Wiring, terminals or connectors With IA, add on Start/stop switch Brake switch Remote Function Actuator (RFA) module Quote Link to comment Share on other sites More sharing options...
