Oil pan and rod bearing - 2012 Edge Limited
nullreference
Guessing I have a bad rod bearing, do I need to remove the engine to take off the oil pan to get a look a the bearing? I know it's not the "correct" repair, but has anyone tried to replace a rod bearing to buy a little time before spending $2k-$3k on a used/rebuilt engine swap? I'm in the Chicago suburbs, just looking for options on how I can get running for as little money as possible, and then what I should be looking for in a
[edit: what I should be looking for in a mechanic.]
2012 Ford Edge Limited - 160,000 miles
Edited by nullreference
