roots57 Posted August 2, 2017 Report Share Posted August 2, 2017 Has anyone wired any electronics thru the cabin fuse panel in a gen II Edge? I recently bought a dash cam and I want to hard wire it. According to the owner's manual, the cabin fuse panel is under the dash to the left of the steering column, pretty standard location. Although at first glance I couldn't even find it. The manual does also say that it "may" be easier to remove the plastic trim cover, which most likely means you cant do shit without removing the trim cover. Any tips would be appreciated! I already bought the hard wire kit that comes with the blade fuse adapter that plugs right into the panel. Thanks! Quote Link to comment Share on other sites More sharing options...
dy57 Posted August 3, 2017 Report Share Posted August 3, 2017 (edited) Here is a video of where it is. Pics: Crazy place to put it... did not pull the trim to find my key code underneath it - PITA. Had to pull the wiring harnesses from their mounts... I'd like to know how to pull the trim as well if I ever need to. Edited August 3, 2017 by dy57 1 Quote Link to comment Share on other sites More sharing options...
redlancer Posted August 3, 2017 Report Share Posted August 3, 2017 Its *way* back there, real pita to get to. Theres a thread on here somwhere about getting to it and good options for which circuit to tap for accesories like ams and radar detectors. Quote Link to comment Share on other sites More sharing options...
