Arebeeem2 Posted July 23, 2017 Report Share Posted July 23, 2017 Hello forum! Glad to have found this spot. I have a 2007 Ford Edge that I purchased a few months ago that had burnt coils. I replaced the coils plugs and had the PCM repaired and the vehicle still refuses to start. It will turn over but will not start. I have checked the fuel and fuel pressure and it is good. I have tested power and signal to the coils and there is no power to the coils. Can someone give me the next steps for my diagnosis? Any and all help is sincerely sincerely appreciated. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 23, 2017 Report Share Posted July 23, 2017 Welcome and sorry to hear. Who did you have the PCM repaired by? Wondering if the as-built data is not matched to your Edge. The Instrument Cluster, which stores the PATS information, and the PCM are likely not talking. And the IC may need to be repaired, but that is a very low probability situation. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 23, 2017 Report Share Posted July 23, 2017 Check fuse 27 in the Smart Junction Box box. (feeds power to the PCM). Ā Check fuse 33 in the Battery Junction Box.(feeds power to the coil packs). Ā If both ok, pull the codes. (Suspect defective PCM, but more checking needed). Whatever the condition causing it, it should set s trouble code. (Code checkers are cheap and easy to use). Ā BTW, in a no-start condition, if you can get it to start, shut it off and let it set. In the no-start condition, raw gas is feed to the catalytic converters. If there's raw gas in the cats when the engine starts, the temp will skyrocket and melt the material inside. Let the car sit to disipate thw extra gas. (There's another procedure where you let it run if you disconnect the air pump, but that's more of a hassle so just wait it out). 2 Quote Link to comment Share on other sites More sharing options...
Arebeeem2 Posted July 23, 2017 Author Report Share Posted July 23, 2017 Thanks for the replies. It was fuse 34 in the underhood box. It's funny because I know that I had checked every fuse. 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 23, 2017 Report Share Posted July 23, 2017 Yay! Good call on fuses, enigma! 1 Quote Link to comment Share on other sites More sharing options...
Arebeeem2 Posted July 27, 2017 Author Report Share Posted July 27, 2017 Soooo. I did get the Edge to start and run. Waited so I didn't melt the cats. Restarted and the engine ran like a v-twin (not in a good way) :-) MIL popped a code P0351. Unfortunately the car is remotely located so I don't get to it easily nor everyday. I replaced all plugs and coils with brand new before I installed the repaired PCM. I haven't tested the #1 coil yet, but I'm trying to see if there are others who have experienced this after doing the plug-coil-PCM repair? Not sure if this is the correct place to post, but I'm also looking for body parts (ds fender and front ds door).Maybe someone can tell me if the 1.5 freshen front end will bolt onto the 1st gen?(I really like the freshened front!) Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 27, 2017 Report Share Posted July 27, 2017 (edited) You may be able to find the sheet metal parts you need from a local parts yard. Just enter your needs and the request will go out to all members. Every parts yard that has the parts, door, fender, etc. will respond to you. Ā http://www.automotix.net/ Edited July 27, 2017 by enigma-2 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 27, 2017 Report Share Posted July 27, 2017 Also check http://www.car-part.com Quote Link to comment Share on other sites More sharing options...
Arebeeem2 Posted July 29, 2017 Author Report Share Posted July 29, 2017 Thanks!! I found a fender! Where is the best place to post my question about the front body clip "swapability" from 1st gen to 1.5 refresh? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 29, 2017 Report Share Posted July 29, 2017 Here, maybe? http://www.fordedgeforum.com/forum/7-exterior-body/ Quote Link to comment Share on other sites More sharing options...
