lwalters71203@gmail.com Posted July 16, 2017 Report Share Posted July 16, 2017 Some one put a new factory amp in our 2008 edge. I am trying to find out if the silver bare wire connects to any of the wires on the amp plug? Quote Link to comment Share on other sites More sharing options...
lwalters71203@gmail.com Posted July 16, 2017 Author Report Share Posted July 16, 2017 All the wires are connected but that silver wire. I am getting no sound unless the plug is moved and getting popping sound Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 17, 2017 Report Share Posted July 17, 2017 There should be no bare wires anywhere in your car. The silver color is a tin coating over the copper. It may be best to rip out whatever wiring is there (sounds like a micky mouse install) and install a known wiring harness. http://www.installer.com/cars/by_car.php?carid=6418 Quote Link to comment Share on other sites More sharing options...
autom8r Posted July 18, 2017 Report Share Posted July 18, 2017 lwalters, The bare silver wire is most likely a shield (drain) wire. It will be connected (grounded) at one end or another, but never at both ends. Normal wiring practice dictates that it is attached to the case ground of the upstream device. Simply, it shields an audio channel (or any other analog signal) from interference. I've attached the wiring diagrams for the audio systems pertinent to your model year (and mine) for your use. There are many variants. You'll notice the shield wire and where it is connected doesn't always follow convention. It seems that in your situation there may be a loose connection somewhere. Check your shields. Personally, I like solder and heat shrink for audio connections. Happy trails. Ford Edge & Lincoln MKX Rep & Wir 2008 pp4948-4969 Audio.pdf 1 Quote Link to comment Share on other sites More sharing options...
