2016 Edge-Heat affecting A/C, Windows, Air Bag and Center Console
billc
Has anyone had issues with their Edge when heat is above 75 degrees? I have had my Edge in 3 times to correct a system shutdown when the temperature hits 75. The sun is out. As above, the A/C shuts down, front windows don't work, air bags shut off, center console is useless. Not on recall list but just checking with the forum. Thank you.
Thank you for the response. The battery reads July 2016. Just doesn't make sense and I (close your ears) sweat easily. Too much time at the dealership and not enough working. Ford Edge Fanatic...any other thoughts that would be obviously be better from the apparent "pro's"?
