billc Posted July 7, 2017 Report Share Posted July 7, 2017 Has anyone had issues with their Edge when heat is above 75 degrees? I have had my Edge in 3 times to correct a system shutdown when the temperature hits 75. The sun is out. As above, the A/C shuts down, front windows don't work, air bags shut off, center console is useless. Not on recall list but just checking with the forum. Thank you. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 7, 2017 Report Share Posted July 7, 2017 How old is your battery? (Thinking that the battery is getting low on electrolyte allowing the battety to overheat and drop voltage). Quote Link to comment Share on other sites More sharing options...
billc Posted July 8, 2017 Author Report Share Posted July 8, 2017 Thank you for the response. The battery reads July 2016. Just doesn't make sense and I (close your ears) sweat easily. Too much time at the dealership and not enough working. Ford Edge Fanatic...any other thoughts that would be obviously be better from the apparent "pro's"? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 8, 2017 Report Share Posted July 8, 2017 Possible lemon. Have had other Edges reported with electrical gremlins. Do you have a lemon law in Canada? Quote Link to comment Share on other sites More sharing options...
PaulSchott Posted July 10, 2017 Report Share Posted July 10, 2017 Your battery may be new but it wouldn't be the first time for something new to be bad. Can you take a voltage reading when the problem accurse? Will the car start if you shut it down during the problem? Quote Link to comment Share on other sites More sharing options...
billc Posted July 10, 2017 Author Report Share Posted July 10, 2017 After my fourth time at the shop they have ordered a new Front Control Interface Module. Will be installed on Thursday. Let's see if it works! Thank you for your help. Glad I'm not paying for it. 1 Quote Link to comment Share on other sites More sharing options...
blockisle9 Posted July 30, 2017 Report Share Posted July 30, 2017 After my fourth time at the shop they have ordered a new Front Control Interface Module. Will be installed on Thursday. Let's see if it works! Thank you for your help. Glad I'm not paying for it. Did it repair the issues? Quote Link to comment Share on other sites More sharing options...
Jasroz Posted July 31, 2017 Report Share Posted July 31, 2017 I have a 2010 with 150k on the engine (I love road trips) and I just recently have been getting overheating issues, hoping its just a blown fuse for the fans or thermostat/gasket issue. I'm surprised to hear its happening on a 2016 though. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 1, 2017 Report Share Posted August 1, 2017 If the coolant has never been flushed, Jasroz, ... Though i too am rooting for it to not be a water pump. 1 Quote Link to comment Share on other sites More sharing options...
