bigmak40 Posted June 30, 2017 Report Share Posted June 30, 2017 Hey all--Having issues with a late 2011 Ford Edge Limited with Sync. I'm getting phantom clicks for one of the HVAC touch screen buttons (specifically, fan speed down button). It clicks down CONSTANTLY; there's no way to keep the fan going as it's always clicking down. It's pretty damn annoying as it's starting to get hot out and we can't keep the fan going as it's constantly clicking down to the lowest fan speed. A couple questions: -Has anybody else seen this? I searched around and didn't see any other similar issues. -Any tips on the part number for the component? I looked through the Ford parts catalog and none of the images matched. -Is there any chance the newer HVAC control with physical buttons instead of the touchscreen will act as a drop-in replacement? Thanks for the help. Quote Link to comment Share on other sites More sharing options...
bigmak40 Posted June 30, 2017 Author Report Share Posted June 30, 2017 The panel in question is this style, with Sony at the top Quote Link to comment Share on other sites More sharing options...
bigmak40 Posted June 30, 2017 Author Report Share Posted June 30, 2017 I did get a part number (BT4Z-18842-CA) for the touch screen panel. Looks like it's not gonna be cheap; general search shows ~$600 for the part. Should I try this part first? Or is there a controller that I should try replacing? Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 30, 2017 Report Share Posted June 30, 2017 First, you can easily find a used one for much cheaper on eBay. Second, you can try to disconnect it to confirm if the issue goes away. If it does, try removing it & clean it. Check this thread: http://www.fordedgeforum.com/topic/22667-what-a-mistake-it-was-to-buy-an-edge/page-2?do=findComment&comment=171727 1 Quote Link to comment Share on other sites More sharing options...
