schrader Posted June 29, 2017 Report Share Posted June 29, 2017 I purchased a 2014 limited and have both fobs, but not the factory 5 digit code. Is there a sequence of fobs and starts/stops you can use on the 2014 to retrieve this code? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 29, 2017 Report Share Posted June 29, 2017 First look in your owner's manual for a card pocket. They previous owner may have put the plastic card which had the factory code on it. If not, there is a code permanently attached to the fuse box. Under the steering column to the left (near the brake) there is a panel. Take the panel off and with a flashlight you will see a white sticker on the fuse box. The white sticker will have a 5 digit code. That is your factory keyless entry code. Using the factory code, you can set your own personal code. Enter the factory code, hold down the 1/2 button for a few seconds and then enter your new 5-digit code that you can remember. Quote Link to comment Share on other sites More sharing options...
akirby Posted June 29, 2017 Report Share Posted June 29, 2017 The procedure should be explained in the owner's manual. If you don't have one get the electronic version at owner.ford.com or www.motorcraftservice.com. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 29, 2017 Report Share Posted June 29, 2017 I know on later years there's a process using fobs, not certain about the 14 m/y. The process is simply enough. Firdt use your owner's manual to locate the "backup slot" in the car's center console, then insert the first key and push the engine start/stop button. Wait a few seconds, and push the button again. Remove the first key, insert the second key, and push the button a third time. The factory keypad code should flash on the car's information screen. Quote Link to comment Share on other sites More sharing options...
schrader Posted June 30, 2017 Author Report Share Posted June 30, 2017 (edited) Thanks for the response. I found the code on the fuse block. I tried the fob in the slot routine and couldn't get it to work. I have seen it done on different year cars and trucks, but it wouldn't work on the 14 Edge. It might be something different with the sequence.....it seems that all years and models are a little different in the sequence or setup. Thanks for the help. Edited June 30, 2017 by schrader Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 1, 2017 Report Share Posted July 1, 2017 Thanks for the response. I found the code on the fuse block. I tried the fob in the slot routine and couldn't get it to work.Yoy have to use both IA's. But it probably doesn't work for the 14 m/y. Quote Link to comment Share on other sites More sharing options...
