Replaced front pads and rotors, now getting noise...
When I turn. Replaced them 2 weeks ago and just started to notice it a few days ago, even after talking a 600 mile road trip. Had no problems at all on the trip, but now starting to get some rubbing noises when I make turns and enter traffic circles. Replacement was pretty easy -- no issues but the brake pad clips were giving me some issues setting down in the grooves. I am wondering if they are rubbing against the rotor. I guess I should have just bought some new clips but they cleaned up pretty well and seemed in good condition after 50K miles.
Did you just replace the pads? If you did not completely pull everything apart and clean then re-grease the pins etc. even the clips and caliper bracket surfaces then you may have noise. The caliper pin boots come out (rubber boots) inside the caliper. Take them out clean them up or replace them. Make sure the clips are in the correct position.
The other issue is if the rotors on the inside are any good. The front rotors an notorious for heavy built up rust and damage. If you did not replace the rotors then this may be the issue also. The outside of the rotor will look perfect, but the inside rotor surface will be damage from heavy rust.
So I am at work now but I took a look at the clips and I think one of the sides are installed wrong since they look different. I attached pics of the passenger side and driver side for comparison. If I had to guess I'd say the passenger side is wrong. Any advice?
EDIT: So it's definitely the passenger side!!! I can see the scratch marks on the rotor from the clips being backwards!!! Crap!!! I hope I didn't ruin these new rotors!!!
Edited by Mirage52
So I just felt the rotor where the clip is rubbing against it. I can feel a groove on the rotor. My question is, will reinstalling the clips correctly and then braking eventually smooth them out? Or will this create a hot spot on the pads and cause them to wear irregularly? Did I just royally screw myself?
Edited by Mirage52
