Rear premature wear inner tire
LF321!
2013 Edge AWD 41K miles
Hi, there is premature tire wear on the inner edge of each of the rear tires. The left (driver) side shows more than the right side. The original tires were replaced at 20K, right before we purchased the car in 2015. There was an alignment done be a Ford dealer 4 months ago, when I originally noticed the wear. It appears to have gotten worse since then, so I doubt the rotation helped. We don't haul heavy items in the car. Could this be a rear shock issue? Any other comments/suggestions would be appreciated.
Thanks!
Certainly sounds like an alignment issue, doubtful it is a tire issue.
Inner Edge/Shoulder Wear
Inner edge (or shoulder) wear occurs on the inside edge of the tire and is usually caused by excessive toe out and/or excessive negative camber. If the tread depth of the outer shoulder is at least 50% greater than the tread depth of the inner shoulder, the tire is experiencing inner edge/shoulder wear. To determine whether tires have this type of wear, visually inspect the tires. In some instances, it may be necessary to measure the tread depth of each rib and compare it to that of the shoulder.
2009 Edge Alignment Specifications
Item LH RH Total/Split
Front
Camber -0.1° ± -0.75° -0.6° ± -0.75° 0.5° ± 0.75° a
Caster 4.3° ± 0.75° 4.5° ± 0.75° 0° ± 0.75° b
Toe — — 0.10° ± 0.20°
Rear
Camber -0.45° ± 0.75° -0.45° ± 0.75° 0° ± 0.75°
Thrust angle — — 0° ± 0.50°
Toe +0.05° ± -0.20° +0.05° ± -0.20° 0.10° ± 0.20°
a Camber Total/Split = LH Camber — RH Camber
b Caster Total/Split = LH Caster — RH Caster
Do you have the alignment sheet from the ford dealer, so we can see the before & after?
Edited by WWWPerfA_ZN0W
Thanks WWWPrefA_ZNOW, your reply was very helpful. I don't have the alignment sheet from the work done (my bad!) and only have the bill/receipt. It sounds like I can rule out any issues with the rear shocks, correct. Also, I'll get another alignment and replace the rear tires. The Edge is an '13. Would the stats you provided for an '09 Edge be the same? I'll bring a copy of the stats you provided to the dealer.
My experiences have been worn rear shocks causing inside wear on the rear tires every time. Check the shocks for a damp or wet area. I have seen this wear as early as 60K miles with shocks. The back up would also be an alignment and wheel bearing check.
