Cree Posted March 20, 2019 Report Share Posted March 20, 2019 On 6/23/2017 at 9:52 PM, Xtra said: Just arrived and time for another un-boxing. The parts came fast enough but the packaging was not that great. All the parts arrived in good condition , but the hardware bag of nuts and bolts was open and some had spilled out. I will not know if some are missing until the install. There were no instructions and only a generic video in Chinese on line that was no help. Galpin Auto Sports will do the install http://galpinautosports.com . I have instructed them to only use the parts that bolt on . If holes have to be drilled then I won't install that part. Can't say much about the fit yet , but the finish is great. The paint is small metal flake blue and the strut brace is polished to a show finish. The Edge is very stiff platform to begin with. Mine has the Panoramic Vista Roof, so with a big hole cut in it adding stiffeners can only help out. I would not think it necessary for a car without the Vista Roof. This is the kit as advertised. This is how it arrived. This is what was inside the package I did not get a good photo of the nuts and bolts package so you wont see that. This is the main thing I am interested in, the Strut Tower Brace. It should provide the greatest bang for the buck. It has a mirror polish, nice engraving in the middle, the ends are stamped TTCR-II and the welds look top notch. Lets hope it fits and works as good as it looks. Note the date was not set on my camera...it is not 10-2008 Expand Hey xtra, did you see how they installed this on your car? Did they have to take out the windshield screen and/or anything else? I just got one of these and was going to try myself. Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted March 21, 2019 Report Share Posted March 21, 2019 (edited) On 3/20/2019 at 11:52 PM, Cree said: Hey xtra, did you see how they installed this on your car? Did they have to take out the windshield screen and/or anything else? I just got one of these and was going to try myself. Expand When I installed my strut tower bar on my 2013, I had to remove the windshield wipers and the cowl grille. You definitely want to torque the arms to spec: Torque: 18 lb.ft (25 Nm) Over tightening can crack your windshield. Edited March 21, 2019 by onyxbfly Quote Link to comment Share on other sites More sharing options...
Cree Posted March 21, 2019 Report Share Posted March 21, 2019 Thanks onyx, You know if any DIY write up on this? Definitely want to avoid cracking the windshield. Maybe easier just to have a pro do it Quote Link to comment Share on other sites More sharing options...
Xtra Posted March 21, 2019 Author Report Share Posted March 21, 2019 (edited) The hard part is getting to the rear bolt as the space is very tight . onyxbfly has a 2013 G1 Edge and the install is different for him . If you don't have the tools or do not want to do it yourself then go ahead and let a pro do it. This is much more difficult than installing the catch can and you should use a torque wrench. Some of the X braces are not the same as mine and may have polishing flaws or may not be stamped or etched like mine. I found that the Addco rear sway bar works great with the strut tower X brace and the H&R springs. Edited March 21, 2019 by Xtra 1 Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted March 21, 2019 Report Share Posted March 21, 2019 (edited) On 3/21/2019 at 7:42 PM, Xtra said: The hard part is getting to the rear bolt as the space is very tight . onyxbfly has a 2013 G1 Edge and the install is different for him . If you don't have the tools or do not want to do it yourself then go ahead and let a pro do it. This is much more difficult than installing the catch can and you should use a torque wrench. Some of the X braces are not the same as mine and may have polishing flaws or may not be stamped or etched like mine. I found that the Addco rear sway bar works great with the strut tower X brace and the H&R springs. Expand Xtra is right. I installed it on my 2013. I did not install it on my 2017 Sport. The torque spec I previously quoted was for the wiper arms on the 2015-2018 edge. Edited March 22, 2019 by onyxbfly 1 Quote Link to comment Share on other sites More sharing options...
