BigWilly Posted June 18, 2017 Report Share Posted June 18, 2017 I have a 2017 Edge Titanium and last night we went to a drive in theater. I couldn't get the lower fog lights to turn off with the vehicle running at all. I ended up tapping my rear floor mats over them. I checked the owners manual to find a fuse to pull but couldn't find one in either the under hood or in car fuse panels. Ford included an option to turn off all interior lights but not th exterior ones? Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
lildisco Posted June 18, 2017 Report Share Posted June 18, 2017 To my knowledge, the US doesn't have any fog lights. If you're referring to the Daytime Running Lights, the only way to turn them off is to go through the menu on the instrument cluster on the left side. I forget what exactly it's under, but that's the only way to turn the daytime running lights. Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted June 18, 2017 Report Share Posted June 18, 2017 the triangle LEDs are signature lights that are wired directly to battery, when car is on, they will be on. The DRLs for all model 2015up are in the headlights on both HID and non HID models 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 19, 2017 Report Share Posted June 19, 2017 No "dark mode" available then, Nick? Quote Link to comment Share on other sites More sharing options...
lildisco Posted June 19, 2017 Report Share Posted June 19, 2017 Nick is correct. I thought that you could disable the LED Signature Lights, but you can't through the instrument cluster. I thought that i was able to disable them at one point. Maybe it was through FORScan, not sure Quote Link to comment Share on other sites More sharing options...
jmr061 Posted June 19, 2017 Report Share Posted June 19, 2017 There is no programming for the LED signature lights. They are hardwired and trip with RUN position. You need to pull the fuse which is Fuse 20 in the under the hood fuse block. The SM indicates this fuse also send power to the headlamp assemblies and the headlamp switch. 1 Quote Link to comment Share on other sites More sharing options...
VisionPilot Posted June 20, 2017 Report Share Posted June 20, 2017 Has anyone figured out a way to disable the cargo / hatch area light? Quote Link to comment Share on other sites More sharing options...
akirby Posted June 20, 2017 Report Share Posted June 20, 2017 Other than a hammer or wiring in your own switch, I don't think so. 2 Quote Link to comment Share on other sites More sharing options...
candurin Posted June 20, 2017 Report Share Posted June 20, 2017 Pull out the bulb... 1 Quote Link to comment Share on other sites More sharing options...
