shark56 Posted June 14, 2017 Report Share Posted June 14, 2017 Hello, I have a 2013 ford edge with 3.7L engine. I need to replace my bank 1 sensor 2 oxygen sensor. Problem is I have no idea where it is and would like to do this repair myself. If anybody could provide some insight on where that sensor might be, I would greatly appreciate it. Thanks! Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 15, 2017 Report Share Posted June 15, 2017 Bank one is the same side as spark plug one (drivers side). Sensor 2 is just aft the catalytic converter (follow the cat back and look for an electrical connector. This YouTube video may help with the how to. Always use Motorcraft O2 sensors when replacing. 1 Quote Link to comment Share on other sites More sharing options...
autom8r Posted June 15, 2017 Report Share Posted June 15, 2017 Shark 5 6 Bank 1 HOS 2 is located on the firewall side. In the vicinity of the oil pan drain bolt and lower engine mount. Happy trails. 1 Quote Link to comment Share on other sites More sharing options...
shark56 Posted June 18, 2017 Author Report Share Posted June 18, 2017 Thanks for the responses! Ive located the sensor and ready to replace it. Are there any specialty tools needed for this job?. I can slip a combination wrench on it but have to room the move it. Not really any space to work with. Also the electrical connection looks like it will be a pain. Any advice or tips would be appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 18, 2017 Report Share Posted June 18, 2017 This video should help. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 19, 2017 Report Share Posted June 19, 2017 They make a socket especially for oxygen sensors, maybe you can borrow that from your local auto parts store? 1 Quote Link to comment Share on other sites More sharing options...
autom8r Posted June 20, 2017 Report Share Posted June 20, 2017 Oxygen sensor wrench. I recommend disconnecting the wires before turning. Practice on the Bank2 upper HOS connector (top, radiator side) to get a feeling on how to disconnect. It should be the same connector type used on Bank#1 lower HOS. Use a little penetrant to get the old one to unscrew. Put a little dab of anti-seize on the threads of the new one. Wipe off excess. Don't get any on the sensor. Happy trails. 1 Quote Link to comment Share on other sites More sharing options...
cox Posted August 4, 2024 Report Share Posted August 4, 2024 hi guys is this good? i run Fordscan and i get this values idk what means. [Catalyst Bank 1] Oxygen Storage Capacity MID: 21 TID: 81 Value: 0.949 :1 Min: 0.000 :1 Max: 0.816 :1 [Catalyst Bank 2] Oxygen Storage Capacity MID: 22 TID: 81 Value: 0.969 :1 Min: 0.000 :1 Max: 0.828 :1 Quote Link to comment Share on other sites More sharing options...
