SSM 46355: 6F35 Harsh Reverse, Delayed 3rd/5th Up/DownShifts
February 2, 2017 MANUFACTURER COMMUNICATION NUMBER: SSM 46355
Summary
MULTIPLE 2014-2016 VEHICLES EQUIPPED WITH 6F35 TRANSMISSION AND BUILT ON 1-JAN-2014 AND THROUGH 31-DEC-2015 MAY EXHIBIT HARSH REVERSE ENGAGEMENT AND HARSH/DELAYED 3RD AND 5TH GEAR UP/DOWN SHIFTS WITH NO DTCS PRESENT. THIS MAY BE DUE TO A MECHANICALLY BINDING SHIFT SOLENOID B (SSB). VERIFY HARSH REVERSE AND 3RD AND 5TH GEAR SHIFT EVENTS ARE PRESENT. USING IDS, IDENTIFY THE BAND NUMBER OF SSB FOR USE WHEN ORDERING PARTS. REMOVE THE MAIN CONTROL. DISASSEMBLE AND THOROUGHLY CLEAN THE VALVE BODY AND SOLENOID BODY TO REMOVE ANY CONTAMINANTS. REPLACE SSB, REFER TO WORKSHOP MANUAL (WSM) SECTION 307-01. USING IDS, CLEAR TRANSMISSION ADAPTIVE TABLES. FOR CLAIMING, USE CAUSAL PART 7G383 AND APPLICABLE LABOR OPERATIONS IN SECTION 7 OF THE SERVICE LABOR TIME STANDARDS (SLTS) MANUAL.
MAKE MODEL YEAR
FORD C-MAX 2015-2016
FORD EDGE 2014-2016
FORD ESCAPE 2014-2016
FORD EXPLORER 2014-2016
FORD FIESTA 2014-2015
FORD FOCUS 2014-2016
FORD FUSION 2014-2016
FORD TAURUS 2014-2016
FORD TRANSIT CONNECT 2014-2016
LINCOLN MKC 2015-2016
LINCOLN MKT 2014-2016
LINCOLN MKX 2014-2016
LINCOLN MKZ 2014-2016
Thanks for the usual updates & information. But having the Lincoln MKX & MKT mentioned in the SSM when there are no MKX or MKT models equipped with the 6F35 Transmission is concerning. Gives the impression their own data is not reliable, who knows what other information they have is incorrect & how it might affect things, in a bad way.
