N-edge16 Posted May 31, 2017 Report Share Posted May 31, 2017 I have 2016 Edge titanium with sync 3. I installed android auto app on my phone but android auto icon doesn't show up on car display. Any thoughts? Quote Link to comment Share on other sites More sharing options...
akirby Posted May 31, 2017 Report Share Posted May 31, 2017 Are you still running Sync 3 1.0? You need at least 2.0. 2.2 is available for installation at owner.ford.com. Quote Link to comment Share on other sites More sharing options...
N-edge16 Posted June 1, 2017 Author Report Share Posted June 1, 2017 Thanks for the tip. It was indeed the old version and I have no idea why I wasn't upgrading on Wi-Fi. Installing from the USB drive fixed the problem. Quote Link to comment Share on other sites More sharing options...
N-edge16 Posted June 2, 2017 Author Report Share Posted June 2, 2017 Are you still running Sync 3 1.0? You need at least 2.0. 2.2 is available for installation at owner.ford.com. Do you know how I can setup Apple car play? upgrading to v2.2 added Android auto, but I have problem with Apple car play. Quote Link to comment Share on other sites More sharing options...
davidw Posted June 2, 2017 Report Share Posted June 2, 2017 Do you know how I can setup Apple car play? upgrading to v2.2 added Android auto, but I have problem with Apple car play. You need a new USB hub from the dealer that supports Apple Car Play. Should run about $60-70. Did the same Sync3 2.2 update and USB hub swap in my 2016 Focus and it took about an hour total between the update and the hub install. 1 Quote Link to comment Share on other sites More sharing options...
N-edge16 Posted June 2, 2017 Author Report Share Posted June 2, 2017 You need a new USB hub from the dealer that supports Apple Car Play. Should run about $60-70. Did the same Sync3 2.2 update and USB hub swap in my 2016 Focus and it took about an hour total between the update and the hub install. Thanks much for your help! Quote Link to comment Share on other sites More sharing options...
